butterfly valve position
- gigolojoe
30 Apr 2010 12:52 #364472
by gigolojoe
butterfly valve position was created by gigolojoe
Hi,
I'm installing new throttle cables. What position should the butterfly valves on the carbs be in when you go to start the bike and have hands off the throttle? Should they be fully closed or open a little bit?
Thank You
Thank You
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
30 Apr 2010 13:33 #364484
by Skyman
West Linn, OR
Replied by Skyman on topic butterfly valve position
"Just cracked" is a good starting point. Then adjust as needed after started, and warmed up.
West Linn, OR
- TeK9iNe
- What did you do!?!
- Thank you received: 28
30 Apr 2010 15:57 #364515
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic butterfly valve position
Skyman wrote:
:evil: Cracked wide open that is! :laugh:
Nah, he's right. Hold them up to a light and adjust the idle knob till theres "just a crack" of light coming thru about a half inch wide.
Try and start like that - Full choke, NO THROTTLE input.
If that doesnt work, increase idle a full turn, then retry.
if you still have trouble starting after 5 turns/attempts, try manipulating the choke to about 1/4 less.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
