Fuel pump and pressure regulator
- Ituen
- Rider
30 Apr 2010 01:46
I'm collecting parts for my blow-through turbo application. I was looking at a MSD 2225 for a fuel pump and Mallory 4309 for the FPR. Has anyone had any issues with these parts? Any tips?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- Samwell
Re: Fuel pump and pressure regulator
30 Apr 2010 04:18
Ituen wrote:
I'm guessing that this will be a fuel injected turbo? The MSD should flow enough gas. Normally you want your pump to supply about 30% more than you need - this allows for constant flow and pressure. (better than if your pump is just up to the task)
The piston/solenoid type pumps are noisy, the gear based ones are more reliable and quieter (and pricier).
Out of curiosity why use different brands, why not use Mallory for both?
- Ituen
- Rider
30 Apr 2010 12:37
No fuel injection, I'm using the factory carbs. Those parts were recommended to me from another forum. I'll look into using the same brand.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- PLUMMEN
30 Apr 2010 12:39
what is it going on and which carbs are you using? dont forget a good ignition
- Ituen
- Rider
30 Apr 2010 13:50
I have an 82 KZ750. I'm using the factory carbs and a Dyna 2000 ignition is on the list.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- MFolks
30 Apr 2010 14:28
Don't forget to use pressure rated fuel lines after the pump, anything before the pump should work as it won't be under pressure.
For clamping purposes, use fuel injection clamps as the standard "Worm" clamp will cut the fuel lines over time.
- Ituen
- Rider
01 May 2010 02:07
Thanks for the tip.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
