- Thank you received: 12
1982 550 LTD TK 22 choke doors?
- apbling
I have a 1982 550 LTD with TK 22 carbs. I have a really badly plugged pilot circuit on one of them and managed to break a piece of a dental pick off in it trying to clear it...
Anyway, I was thinking of picking up a set of carbs off ebay and started thinking this might be a good opportunity to get some with the doors still attached to the choke mechanism. But then I started thinking if this was a good idea... I already get by with no doors, and they are known to fall off, possibly causing engine damage. Would I be better off toughing it out without the doors instead of risking them falling off and causing damage?
- loudhvx
- Thank you received: 1616
In order to start the bike without the doors and without some other way of choking, you will likely have to jet up too much and will be too rich after it warms up.
There are a bunch of threads here on TK-22 carbs chokes etc. Try a search.
Also, I have some tk-22 info about the fast-idle set screw which might help you out. I'm working on a page dedicated to TK-22 info, but it's still in the works.
home.comcast.net/~loudgpz/GPZweb/Carbure...PZchokeScrewMod.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- apbling
Well, I diassembeled mine completely to soak because my #4 pilot circuit passage is plugged just before it enters the carb throat and I'm having a heck of a time clearing it. This it he first time I got a REALLY close look at my doors and the pins and hinges are there...but where the hinge attaches to the door is where it broke! all four chokes broke in the same place. I wonder where the the heck these doors went... I'm almost thinking the PO removed them because I don't have any damage or I haven't found the doors anywhere.
My choke right now is stuff a hankerchief in the airbox intake. works ok at best...but I've been doing it for 6 yrs, so I'm getting good at it
- loudhvx
Yep, once you get the knack, it's not too bad. And no one else will be able to steal it unless they like pushing the bike! :laugh:Thanks for the reply. I was actually do a search and reading up on these. A dedicated page would be great.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
kzrider.com/index.php?option=com_kunena&...d=3&id=349339#350926
another one you can try is to make all 4 choke plates solid with no flaps. Then use the choke lever the same way you use the kerchief. Someone else here has done that and reported good success. It allows you to set the choke to a certain position to allow the motor to idle and rev a little so you can start riding even when it's cold.
1981 KZ550 D1 gpz.
Other links.
- harm
- Tom
- Thank you received: 13
Loudhvx has wanted me to take some pics of this for some time now but i still haven't yet:unsure:
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- apbling
That sounds easier and less risky too... did you use just regular epoxy glue? How did you get it to form and not sag or make a huge damn mess?
BTW, I live in WI some guy just sold a 550 like yours... He had it marketed as a 1100R 1/2 scale. Is 550 a project you did or did Kawie make them like that?
- harm
- Tom
Actually a friend from work put the epoxy on for me. He used a two part epoxy. I'm not sure how he did it without making a mess but i could ask him. After it was cure i knocked off the high spots with a belt sander. They turned out real nice.
Kaw didn't make them quite like mine, they did make the GPZ550 which is quite similar. Here is the link to my project:
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=154651
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- harm
- Tom
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- apbling
I was thinking... What do you think about cutting out the doors (I was going to use thin stainless steel) and epoxying them in place. Then take a drill (start small and can always make it bigger) and drill a hole in the center of the plate I made. That way I can close the choke completely, but some air will still be able to pass through?
- harm
- Tom
Try it! That would probably work too!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- loudhvx
Play with it before you drill any hole. If you find need it cracked a tiny bit from the start, then drill an appropriate hole. But smaller is always better. The colder the air, the smaller the hole will need to be.
Typically, the more air that leaks past the choke, the more throttle you will have to give it as you crank it.
1981 KZ550 D1 gpz.
Other links.
