stock settings for a 82' 750M1 csr twin
- gr8funbikes
02 Apr 2006 20:46
I don't have a manual for my 82' 750M1 csr twin and want to go through the carbs but not too sure of the stock settings. Does any body know the setting for the jets and what the floats should be set at?
Thank you for your help.
82 KZ 750 CSR Twin
- wiredgeorge
Re: stock settings for a 82' 750M1 csr twin
03 Apr 2006 05:29
I am sure that our fine 750 owners will chime in eventually but the service fuel level is about 1/8" below the gasket mating line if memory serves (my carburetor specs are up in the shop). For jetting, go to buykawasaki.com and look in the Parts Diagrams under the Owner Info section. The jetting will be in "Carburetor Parts" I think.
- gr8funbikes
03 Apr 2006 17:25
wiredgeorge:
Again thank you very much your tech info in my posts have been very valuable. Thank you.
82 KZ 750 CSR Twin
- wiredgeorge
03 Apr 2006 19:35
Thanks... I have full specs on the twins but that stuff is up in my shop... if you don't get the help you need, drop me a note on my carb forum on my web site... Thanks!
- steell
03 Apr 2006 20:36
76-80 models of teh 750 twin I could tell you, but the 82 model has the air injection system and I suspect the carb settings will be different (leaner for EPA).
I had an 82 for a short while but sold it because I hate the CSR ergonomics and the leading axle fork (the whole CSR concept really). There are a few 82 owners on here, maybe one of them has a manual.
- gr8funbikes
04 Apr 2006 18:54
wiredgeorge:
Thanks for the help. I will look a little moreabut I may have to take you up on that offer.
Steell:
yea I would think that they would be different. BTW I took a look at your site and WOW your bikes look incredible. I especially liked the one you painted blue with the flames.
Steell:
82 KZ 750 CSR Twin
