- Thank you received: 10
how do i check float levels?
- Kitten Tooth
25 Apr 2010 20:00 #363203
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
how do i check float levels? was created by Kitten Tooth
Ok, you guys told me that i should check my float levels on my carburetors. Sorry, not sure how to do that unless that just another name for something. So... how do i check float levels?
Thanks,
KT
Thanks,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
25 Apr 2010 21:45 - 25 Apr 2010 21:46 #363215
by Skyman
West Linn, OR
Replied by Skyman on topic how do i check float levels?
The basic concept is that you use clear vinyl tubing and attach it to the float bowl drain. On the tube, use a fine Sharpie pen to mark two horizontal lines that show the correct specified fuel service level for your carbs (usually about 3mm).
Some carb types have a nipple and a valve screw that makes this easy. Other carbs just have a drain screw, and you've got to get a special attachment to connect the tube to the bowl drain.
Is this your KZ1000 we're talking about here? Does it have BS34 carbs? If so, you should have the drain nipples.
Put the bike up on the center stand. Attach one end of the tube to the float bowl, and hold the other end of the tube against the side of the carb body with your marked lines higher than the top of the float bowl. Turn your petcock to "ON" (if non-vacuum petcock), or "PRI" if you have a vacuum petcock. Open the drain valve screw a few turns until you see fuel flowing freely into the tube. Wait until the fuel level stabilizes, then slowly lower the tube until the top line on the tube is even with the top of the float bowl. Do not raise and lower the tube multiple times as this will give you an inaccurate measurement. Just lower it once until your top line is even with the bowl top, then observe the fuel level in the tube. If set correctly, the fuel should be within 1mm of the lower line.
If incorrect, you will need to adjust you float levels by removing the float assembly and bending VERY SLIGHTLY the "tang" that pushes the float valve.
West Linn, OR
Last edit: 25 Apr 2010 21:46 by Skyman.
- Kitten Tooth
25 Apr 2010 22:23 #363220
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic how do i check float levels?
do i bend the tang closer to the needle? Im guessing so. Thank you very much for this information. I'll do this tomorrow if it doesn't rain.
Thanks man,
KT
Thanks man,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- bountyhunter
- Thank you received: 337
25 Apr 2010 23:03 #363230
by bountyhunter
Replied by bountyhunter on topic how do i check float levels?
Kitten Tooth wrote:
That will make the fuel level in the bowl go LOWER since the fuel will cut off at a lower position of the float.do i bend the tang closer to the needle?
- Kitten Tooth
26 Apr 2010 12:15 #363304
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
ok, i see. Also, does the hose have to be a certain length? are the two lines 3mm away from the end of the tube?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- otakar
26 Apr 2010 12:19 #363305
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic how do i check float levels?
The hose can be any length within reason. It makes no difference.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Skyman
26 Apr 2010 12:48 #363311
by Skyman
West Linn, OR
And the lines should NOT be at the very end of the hose. My suggestion would be to use a tube with is at least 12" long, and put the markings about 8" from the end that you attach to the bowl.
West Linn, OR
- Kitten Tooth
26 Apr 2010 16:53 #363371
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
ok thank you very much, ill check them out as soon as it stops raining.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
