- Thank you received: 1
Main jet plug chop results
- spudbudy
- Kick it like you mean it
25 Apr 2010 11:42 #363098
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
Main jet plug chop results was created by spudbudy
Ok Gang, here are the plug results after doing the airbox mod that increased the intake size @300%. The plugs look lean to me but what do I know it could just be I didn't run it hard or long enough to get good coloring on the plugs.All plugs were run @ least 1/2 mile. let me know what you all think.
s640.photobucket.com/albums/uu129/spudbu...0jet%20plug%20chops/
- TeK9iNe
- What did you do!?!
- Thank you received: 28
25 Apr 2010 11:52 #363105
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Main jet plug chop results
Looks like you didnt run long enough to color them. New plugs SUCK for this, as well as new super clean detergent gas.
Forget the plug chop crap, your just wasting money.
What Jet gave you the most power/fastest accelleration?
Keep going richer till you get the peak power out of her, then stick her on one size richer.
Why not just run pods?
The airbox is designed as a tuned area of back pressure like a speaker. Any change to pass more air ruins the tuning... or makes it better! Who knows... could of screwed it or revolutionized air box dynamics. :laugh:
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- spudbudy
25 Apr 2010 12:08 #363114
by spudbudy
Replied by spudbudy on topic Main jet plug chop results
Yes I agree the plugs all look lean I'm thinking maybe its the brand of gas as I use 2 different ones who knows.so far all the runs I've done in 4th gear kinda run outta stream around 9K give or take a few hundred rpm I'm going to keep upsizing and see what happens. as long as I have bigger jets to try.
