- Thank you received: 10
Got my carbs in the mail, what needs done?
- Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Kitten Tooth
Thanks guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- 900Z1
www.wgcarbs.com/forum/index.php
Good luck!
- roy-b-boy-b
- Thank you received: 103
Remove the cable to see if the bike will idle down. Roy
- Thank you received: 2098
...bike is a stock 1981 KZ1000LTD K model. The carburetors that i ordered were off of a stock 1981 KZ1000 police bike. When i rev the motor, it takes forever for the RPMs to come back down again. It also spits and coughs out of the intake side of the carburetors as you are revving it. I just want to know what the issue is. The carburetors have not been synced, but they were not pulled away from each other when they were cleaned. I ran the bike without an airbox just for testing which was not and issue with the carburetors that were off of my dad's stock 1981 KZ1000 LTD K model bike....
Perhaps pilot circuit is too lean.
Could try adjusting the pilot air screws.
Start by screwing them in clockwise until lightly seated, then back out 1.25 turns.
Screwing in enrichens pilot mixture.
Screwing out leans pilot mixture.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
DONT ASSUME they are correct. If they are off by more than 4-5mm, the bike will simply not run properly.
EVERYTHING from the air filter/box to the exhaust tip must be installed and AIR TIGHT, or nothing will work correctly.
Air leaks and parts missing causes the fuel map/curve of the carbs to change dramatically, essentially making the bike un-usable.
Make sure that the ignition advance mechanism is properly lubricated and returning to idle position.
All these things must be done as part of regular maintenence after many years of service/sitting.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JMKZHI
- Thank you received: 48
Would you care to elaborate?....They (the carburetors) were cleaned .....
Are the new carbs the same type of carburetors as the LTD?
Or is one set the VM-type & the other CVs?
No airbox? And you say the bike ran fine w the other carbs & no airbox? Really?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Kitten Tooth
Thanks guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
