tuning for 4-1 with supertrap
- azr
23 Apr 2010 16:18 - 23 Apr 2010 16:34 #362692
by azr
1980 KZ750E
tuning for 4-1 with supertrap was created by azr
1980 KZ750. I'm tuning up the bike to sell her. When fine tuning do you tend to stay on the lean or rich side if you have a 4 into 1? I've got a colortune and set things more towards the lean side but she's not liking it, wanting to stall out if left sitting at idle at a light. I've never dealt with the 4 into 1's before. The carbs are jetted correctly for the pipes. Appreciate any advice.
1980 KZ750E
Last edit: 23 Apr 2010 16:34 by azr.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
23 Apr 2010 16:25 #362695
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic tuning for 4-1 with supertrap
Your refering to adjusting the mixture screws in particular I believe.
Set them with a good external tach or vacuum guage.
Basically looking for the plateau of highest rpm/vacuum between the drop offs when turning mix/air screws.
The plateaus could be about an entire turn, so just set them in the middle.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- azr
23 Apr 2010 16:37 #362700
by azr
1980 KZ750E
Replied by azr on topic tuning for 4-1 with supertrap
Sorry I fixed up my original post. I'm using my 'colortune' to fine tune the fuel mixture. I vacuum synched the carbs already using my 'carbtune'. Maybe I will recheck the synch job as well, she's running great but I can't get a smooooth idle. Pops here and there a bit and like I said when sitting at a light for too long she slowly starts to idle down and will eventually stall if you don't throttle up.
1980 KZ750E
- Old Man Rock
- Thank you received: 225
23 Apr 2010 18:14 - 23 Apr 2010 18:17 #362715
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic tuning for 4-1 with supertrap
Whether selling or not... Always on the rich side if anything outside of dialed in...
Don't know if you have all 3 Color-Tune adjustments... My shipment only had the one and I later found there's actually 3 adjustment procedures...
In your case, assuming all other variables are good, based on Lead idle, Richen the pilots 1/8th to 1/4 turn should be close...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 23 Apr 2010 18:17 by Old Man Rock.
- azr
23 Apr 2010 18:54 #362729
by azr
1980 KZ750E
Ok, I'm getting frustrated. I think the carbs aren't pulling enough vacuum...maybe. Now I can't get 3/4 to even up with 1/2, or when I do have them lined up the bike is leaning toward stalling...arrrr. Just a walk through and maybe this will help figure out the error in my ways. It looks like my vacuum is supposed to be around 24. When I hook up the vacuum gauge it is low at 15 or so. I can increase this by screwing out the middle screw. I then balance 1/2, fine. but 3/4 are very low compared to 1/2 and I can't get them up.
1980 KZ750E
- JR
- Thank you received: 449
23 Apr 2010 18:55 #362730
by JR
Replied by JR on topic tuning for 4-1 with supertrap
Ditto. I always prefer just a smidgen on the rich side.
If popping at idle then thinking either air leaks or time to give those screw on the top front of your carbs another half turn and try again
