Carbs leaking like crazy!
- aknisely
23 Apr 2010 08:05 - 23 Apr 2010 08:55 #362584
by aknisely
Carbs leaking like crazy! was created by aknisely
I aquired a '78 kz650b2 on the cheap a couple of months ago. It hadnt run in a few years when I bought it so I did the usual once over. I cleaned and inspected the carbs and rebuilt the petcock. The first time I put gas in it the fuel just ran right out of the drain tubes on the float bowls. I checked all the jets and the float needles when I took the carbs off and they all seemed fine. What is causing this to happen?
Last edit: 23 Apr 2010 08:55 by aknisely.
- Thank you received: 2829
23 Apr 2010 09:55 #362605
by 650ed
Replied by 650ed on topic Carbs leaking like crazy!
Is this happening on all 4 carbs? Assuming the float valves and needles are clean and not damaged, the floats are either upside down or the tabs that contact and lift the float valve needles are not properly adjusted. Another possiblility is that the overflow tube(s) in the carb(s) is cracked. Ed
- TeK9iNe
- What did you do!?!
23 Apr 2010 16:19 #362693
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Carbs leaking like crazy!
Are all the drain screws snug?
Could be the old float valves are leaking, just not usual for all of them at once.
Give the whole rack a good smack on the side with your fist. If some of the flows stop/decrease, then its the valves.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
