Oil Smoke Starting?
- WMKZ900
22 Apr 2010 10:53 #362368
by WMKZ900
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
06 Kawasaki Concours
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
Oil Smoke Starting? was created by WMKZ900
I have a 76 KZ900, stock carbs and air box. When the engine is cold and the choke lever is on full, I get a large amount of oil smoke out of the exhaust till I get it off choke. The higher the oil level the more the problem, it seems. The oil level is corect. What goes?
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
- Thank you received: 2098
22 Apr 2010 11:20 - 22 Apr 2010 11:24 #362377
by Patton
Replied by Patton on topic Oil Smoke Starting?
Smoking exhaust at start-up often results from old hardened valve seals.
Isn't considered a significant problem, and usually vanishes after engine runs a short while.
Valve seals are inexpensive and could be replaced as and when the head is removed for some other reason.
Click > KZ900 valve seal from Z1E
Last edit: 22 Apr 2010 11:24 by Patton.
- bountyhunter
- Thank you received: 337
22 Apr 2010 12:12 #362396
by bountyhunter
Replied by bountyhunter on topic Oil Smoke Starting?
If it only does it with the choke on, it could just be dark exhaust from running so rich.
- WMKZ900
22 Apr 2010 13:08 - 22 Apr 2010 13:11 #362414
by WMKZ900
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
Replied by WMKZ900 on topic Oil Smoke Starting?
Patton,
I think you have it right.
When I start the engine cold, I need to go heavy on the choke / sweetner and this causes the engine to race up to 3,000 to 4,000 rpm. With the slides nearly shut, the vacuum in the intake goes way up and sucks oil in through the valve seals.
Once I get it off choke, there is absolutely no smoke.
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
Last edit: 22 Apr 2010 13:11 by WMKZ900.
- otakar
22 Apr 2010 13:18 #362415
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Oil Smoke Starting?
No eBay APP ID and/or Cert ID defined in Kunena configurationPatton is right about the stem seals. However I would not replace it with the stock Neoprene seals. I would go with the NEW Viton seals. They are only a tiny bit more expensive but are much better. I buy mine from Joe Hooper at Pitstop Performance.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
