- Thank you received: 1
82' GPz 750 BS34 float issues - dies at 5K rpm
- bean
I still think this is due to the float levels, but am hoping to borrow a bank of carbs for this bike off a buddy with the same bike to confirm it's in the carb and not some other issue.
Doesn't sound like these plastic floats have issues with losing buoyancy - but that would explain my issues. I've read of the same symptoms with too high of a float level (which I have) so that's why I'm leaning this way.
The other thing I'm going to look at is the coil power mod to get the best spark possible... Spark was weak, so they could be flaming out at higher RPM.
Messing with the float levels did get the bog point from 4K to 5500 - so I'd like to get that sorted no matter what.
Damn old bikes...
Rabin
Rabin
Rabin
1989 ZX-10 (Reassembly after 7 years)
1979 KZ1000ST (sold)
1982 GPz750 (sold)
- Bad Dad
Damn old bikes...
Rabin
Maybe it is an ignition problem... cutting out at aproximately the same RPM every time - if it were the floats/carbs, you'd think it would do it (act up) at random speeds & RPM's?
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Thank you received: 2098
Remains a mystery why the float tangs can't be adjusted far enough to lower the fuel level a little more. This by definition is screwy. :huh: Maybe a P.O. installed the wrong parts (needles,seats and/or floats). Am presupposing the seat 0-rings were checked and found to be in position.
- bean
I'll find out tonight when I drop it in, up till now it's just been short rides with a thin bit of foam over the airbox lid...
He didn't have faith in the clear tube method, and said the BS carbs were REALLY sensitive to air box, and air flow.. He's also never heard of the plastic floats acting up, and if the fuel stops with the float needle closed that should be good too.
If he's right - it's an easy fix, and I just wasted a whole lot of time...
1982 GPz750 (sold)
- bean
I had never heard or read that CV carbs were so sensitive to the airbox, and never would have thought not having the filter would have caused this issue.
Wanted to post this just in case anyone else ever ran into it.
Thanks very much for all the suggestions, and advice.
Rabin
1982 GPz750 (sold)
- Mcdroid
- Gone Kwackers
- Thank you received: 318
Well - I'm speechless. Put the air filter in, buttoned it up, and the damn bike revved to 10K perfectly... (once warmed of course)
Thanks very much for all the suggestions, and advise.
Rabin
We appreciate you taking the time to post the 'fix'...it does add to the database and will save someone some additional grief in the future.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- GA Joe
