KZ400 '75 carb questions
- Martinbr
19 Apr 2010 07:35 - 19 Apr 2010 08:02 #361651
by Martinbr
KZ400 '75 carb questions was created by Martinbr
Hi guys,
I had my Kawasaki Z 400 rebuild a bit over the winter by a danish firm called Wrenchmonkess. They only worked on the looks and have done nothing to the enginge or carb.
Here is a picture btw:
www.billedeupload.dk/photo/2010-04/e4c5d5ec/z400.jpg
The other day it couldnt start though so i decided to take out the carburators and clean them.
I must admit that i dont have a clue to what im doing But i hope i can learn by doing
Anyway, when i opened up the carburators i could see that the little rubber thingys (i think they are called PILOT PASSAGE PLUGS) where in very very bad shape. One of them fell totaly apart when i took it out.
I guess some of the other stuff in the carburators could also be in bad shape. so i guess it would be a good idea to replace as much as possible.
But is it possible to buy some sort of carburator rebuild kit? And if so, where would be a good place to buy it online?
And does the pilot passage plug come with such a kit?
So far i have just been following the Clymer repair handbook. Is there a better 'carb-guide' somewhere on the internet?
And finally, is there anything i should be aware about?
Here is a picture of the thinghy i think is called pilot passage plug:
www.billedeupload.dk/photo/2010-04/68e7f...20passage%20plug.JPG
And what is theese rubber thinghys in the picture called if i want to buy replacements (if its even possible to find repacements):
www.billedeupload.dk/photo/2010-04/5dd63fd9/rubber.jpg.html
I really hope some of you guys in here can give me a little push in the right direction
And sorry about my english.
Thanks.
regards
Martin
Thanks.
regards
Martin
Last edit: 19 Apr 2010 08:02 by Martinbr.
- timebomb33
- Thank you received: 10
19 Apr 2010 10:35 - 19 Apr 2010 10:36 #361686
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ400 '75 carb questions
a freind of mine just pulled his carbs on his cb750 f apart and the rubber plugs had completly disolved so what we did is get a piece of doweling the same diameter and cut them the right lentgh and epoxied them in to place we used 5 min epoxie so if we ever have take them apart agin it will be fairly easy. worked great. i figured that outfit was all about the look very depressing.
Last edit: 19 Apr 2010 10:36 by timebomb33.
- Martinbr
19 Apr 2010 13:22 #361719
by Martinbr
Replied by Martinbr on topic KZ400 '75 carb questions
Cool i will try that
- Thank you received: 2098
19 Apr 2010 14:37 #361739
by Patton
Replied by Patton on topic KZ400 '75 carb questions
Martinbr wrote:
Carb holder or manifold.
...what is theese rubber thinghys in the picture called if i want to buy replacements (if its even possible to find repacements):
www.billedeupload.dk/photo/2010-04/5dd63fd9/rubber.jpg.html ... sorry about my english....
