- Thank you received: 10
well, found out what the problem was
- Kitten Tooth
14 Apr 2010 21:45 #360760
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
well, found out what the problem was was created by Kitten Tooth
When i asked my uncle chad to help me rebuild my carbs, i told him to try and get as much of the black, flaking paint off of them when he soaked them. The strip fast paint stripper ate the o rings that went around the shaft that turned to open the butterfly on the manifold side of the carb. Thats where the vacuum leak was. it was sucking air through the manifold side of the carb and thats why it was revving up and down by itself. Plus, i didn't know that when you pulled the carbs away from each other and split them all up individually, that it would make them un synced... those carbs are good for part but we'll draw the line at that. At least now i have extra diaphragms and i can re-use the kits i put in them on the new carbs i have coming from ebay that are off of an 81' KZ1000P. I was wondering if the police bike carbs were jetted differently than the stock ones... Are they jetted for more power and speed?
Anyways, thanks guys.
KT
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- MFolks
- Thank you received: 540
14 Apr 2010 21:51 #360762
by MFolks
Replied by MFolks on topic well, found out what the problem was
Carb Parts & O Rings
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbparts.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.sportingforless.com/servlet/the-Carb-repair-kit/Categories
www.cycleorings.com/
www.nrp-carbs.com
www.carbparts.com
www.jetsrus.com
- trianglelaguna
- Thank you received: 235
15 Apr 2010 06:11 #360795
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic well, found out what the problem was
you got skills son!!!!!
1976 KZ900
2003 ZX12R
2007 FZ1000
- Kitten Tooth
15 Apr 2010 18:10 #360951
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic well, found out what the problem was
well, being 14 and all, i am still learning:)
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
15 Apr 2010 20:21 #360986
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic well, found out what the problem was
Jetting always always depends on the requirements of the engine.
An engine has different amounts of air volume it can swallow, all throughout the throttle/rpm ranges. The goal of the carbs is to mimic the air requirement with a precisely controlled amount of fuel across the entire band.
most times that ratio is right around 13.5 air : 1 fuel naturally aspirated stuff, 13.2:1 for turbo/charger/etc.
The jetting may or may not work. There are many other factors that effect this too, like condition of engine, ignition system, exhaust, intake, valves, amount of cam lift/duration/timing, spark timing/advance, blah blah blah...
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
