carbs for 650/750 conversion?
- dnestell
01 Apr 2006 20:10
i'm planning on doing the 650/750 to 810 conversion on my bike. i was wondering what carbs would be a good choice for this application?
- wireman
Re: carbs for 650/750 conversion?
01 Apr 2006 20:17
try some 28s or 29s,ready to sell that 1000 yet?:whistle: goodluck,happy wrenching!
- dnestell
01 Apr 2006 20:40
it is in about a thousand pieces in my buddies garage. i don't have the carbs for that bike yet they are about 50 miles away along with a couple other key parts (long story). waiting for better weather to paint frame and engine. do 28's have a smooth sided housing. my stock carbs are vm24s, i think, and they have a ribbed housing. did 28s come on kz1000s?
- 77KZ650
02 Apr 2006 15:12
I think that 26s, 28s, and 29s, all had the smooth non ribbed sides, my stock 24s are ribbed. I think that kz1000s came with either 26s or 28s or a differnt kind of carb (cv) depending on the yr/model. I'll be looking for 28s for my 810 project:)
Scott
Scott
07 MDP Rookie of the Year
- wireman
02 Apr 2006 15:25
the good 28s came on z1s.kz1000s came with 26s 77-78 79-80s came with newer style smog motor version of 28s,29s are aftermarket they are getting harder to find but they are real good carbs.
Post edited by: wireman, at: 2006/04/02 18:26
- DanOz7Five0
02 Apr 2006 19:53
I ahve he 24s on my 750, but Im just about getting around town mostly. Id go bigger if I had a set, but Im happy with my bike.
- Shoe48
- Live each day as it is your last
02 Apr 2006 20:14
WiredGeaoge has a nice artical on using CV34's on his web site Might check that out ,, lots less money for CV34 carbs ,I have the set that came with my 750 so that is what I will use , Just an idea
:whistle:
Post edited by: shoe48, at: 2006/04/02 23:14
Post edited by: shoe48, at: 2006/04/02 23:15
- wireman
02 Apr 2006 20:22
the problem with carbs over 29 is when you put the bigger boots on there will be a big restriction unless the head is ported to match which i think kind of defeats any gains from bigger carb.thats why 29s were so popular on 900-1000s becuase 33s didnt work good with unported head.
- 77KZ650
03 Apr 2006 18:15
wireman wrote:
Scott
So how do we tell a good 28 from a lesser 28? extra stuff for the smog gear? What is the difference internally that makes them better? and would they do much difference on an 810, or just the bigger bikes?the good 28s came on z1s.kz1000s came with 26s 77-78 79-80s came with newer style smog motor version of 28s
Scott
- The Fish
03 Apr 2006 18:56
Here a link for the differences in carbs
www.z1enterprises.com/reference/z1-carb-guide.aspx
I would be inclined to use the 26mm pumper carbs off a GS 750 Suzuki. The jetting will probably be "in the ball park" with your set up and be easier to get spot on.
The other VM 28mm carbs would require more jetting to get them correct. If I were to choose 1 set of 28mm, I would go with the early Z-1, as they are easier to jet.
The GS 750 carb bodies will bolt right on to your stock 24mm carb backing plate and will allow you to change the (Suzuki)choke cable system to the side lever choke system.
Fish
Post edited by: The Fish, at: 2006/04/03 21:58
Fish
- wireman
03 Apr 2006 19:07
the older style 28s had flatter looking lids and 2 screws on tops instead of 3.
- The Fish
03 Apr 2006 19:22
The earlier old style carbs has flat 2 screw tops and also have a removable drain plug on the bottom of the bowl for easier jet changes. These are the 28mm that I would use if going to 28mm.
Fish
Post edited by: The Fish, at: 2006/04/03 22:22
Fish
