- Thank you received: 6
Jetting help with 1075
- fordtruck
09 Apr 2010 19:15 #359601
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
Jetting help with 1075 was created by fordtruck
I asked for help in my post on the "Engine" forum, but I thought I might get more of a response here.
1977 KZ1000 with MTC 1075cc 10.5:1 piston kit. Head is rebuilt and ported by Pit Stop Performance. Vance and Hine 4-into-1 with competition baffle. VM28 carbs with 20 pilots, 120 mains, and non-adjustable needles. Also have K&N air pods.
Here's the problem. It starts great and idles good, but too high. When cruising down the highway it surges and acts like it's starving for fuel. If I turn on the choke it helps tremendously. I have not done a full throttle run because this is a fresh rebuild.
I think the needles need to be richer. I have a set of shims. Will one shim per needle be enough? I also have the original VM26's that have adjustable needles. Can I use them in the VM28's, or should I just shim the ones in them now?
- racer54
- Thank you received: 114
09 Apr 2010 19:32 #359604
by racer54
Replied by racer54 on topic Jetting help with 1075
I run a 1075 with V&H street header, 29mm smoothbores and pods and have the same jetting except I have my needles raised one notch...or two...can't remember as it's been a few years since I've done it. I would say you need to raise the needles for sure and would just use shims/washers to raise it.Have done it that way before and it works fine. Don't know how thick the washers were I used but you wouldn't want anything really thick as it wouldn't take much. Not sure if the needles will interchange between the two style carbs though. Maybe someone else will know.
- timebomb33
- Thank you received: 10
09 Apr 2010 20:11 #359612
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Jetting help with 1075
what is your elevation that is a good starting point on lots of my hot rod stuff i raise the the needles all the way up with 26 mm 28 mm or even 29 smooth bores. that definitly will richen things up in the midrange for you. the rest of your jetting sounds close to me.
- fordtruck
10 Apr 2010 05:56 #359657
by fordtruck
Replied by fordtruck on topic Jetting help with 1075
I just thought of something that I did wrong that is probably part of my problem. I switched from VM26's to VM28's. I wondered why the 28's had three vents since the 26's only had two. What I thought was an extra vent is a vacuum fitting. I'll cap it tomorrow and see how much that improves it.
- Old Man Rock
- Thank you received: 225
10 Apr 2010 06:33 - 10 Apr 2010 06:37 #359662
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Jetting help with 1075
DOH! :blink: :laugh: :laugh: :laugh:
Several things ware going to occur here...
1) You will be reaaaaaaaal happy something so minor fixed your issues.
2) You are going to be reaaaaaaaaal bummed of something so stupid and you'll have to hear us bust your balls...
"Wall of Dumbass" shame on this one if that's it...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 10 Apr 2010 06:37 by Old Man Rock.
- fordtruck
10 Apr 2010 17:41 #359769
by fordtruck
Hahaha. I figure if that's the dumbest thing that I did on this rebuild, I'm ok with it! I capped the vacuum fitting off tonight and it helped, but it's still running way lean. I took the carbs off and shimmed the needles. I also took the 120 mains out and replaced them with 122.5.
I also took the intakes off and resealed them just to be sure I didn't have a leak. I'll put the carbs back on in the morning and see how it runs.
- Old Man Rock
10 Apr 2010 17:57 #359779
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Well unfortunately you already changed the mains without testing the needle clip change Larry mentioned first...
One tip of advice that I learned off Larry and Plummen for jetting...
Do one jet change at a time otherwise you'll be chasing the issues all over the place...
Start with your mains and get that dialed in.
Then needle/clip positions and get them dialed in.
Then pilots/slow jets.
Your close so keep at it.... It will be worth the learning curve with out a doubt...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2237
10 Apr 2010 18:23 - 10 Apr 2010 18:27 #359799
by TexasKZ
Replied by TexasKZ on topic Jetting help with 1075
Here are two articles about adjusting VM carbs.
AAAAARRRRRGGGHHHH!!!!
They are pdf. If you would like them, send me a pm and I'll email them.
Last edit: 10 Apr 2010 18:27 by TexasKZ.
- fordtruck
11 Apr 2010 09:35 #359938
by fordtruck
After putting the carbs back together last night, I got to thinking about how the shims help. The slides in these carbs have a floating needle with a spring on them. The clip on the needle doesn't rest on the slide like my old ones. The holes in these slides are drilled out bigger and the whole needle assembly sits inside this hole. The spring goes in first, followed by the needle. The spring keeps the needle pressed up against the part of the throttle linkage that screws to the slide.
On top of the needle clip is a bushing that prevents the needle from raising up into the recess of the throttle linkage. The only way I see to richen the needles is to either file the bushing thinner or replace it with washers. Before I go modifying parts that I'm sure can't be bought anymore, I'd like to hear from someone else that has run into this problem.
The other thought that I had would be to use the slides out of my VM26's. Is that possible? It would solve the needle issue. The slides in my old VM26's are 1.5. The VM28's are 2.0.
Also I don't see how it would be possible to just swap needles with my old VM26's. Those needles are probably 3/8" longer.
- nads.com
- Thank you received: 20
11 Apr 2010 19:47 #360016
by nads.com
Replied by nads.com on topic Jetting help with 1075
Bigger main jets will solve your problem. Put some in and move on.
- fordtruck
13 Apr 2010 08:52 #360340
by fordtruck
Replied by fordtruck on topic *Update* Re:Jetting help with 1075
I posted on another forum about the surging problem that I was having. I received on suggestion to clean and oil the K&N's. The poster said he had surging problems and did this and it helped. I was very skeptical since my filters looked clean, but at this point I was willing to try anything.
Long story short, I don't think my pods had any oil on them. I bought them used off of Ebay and since they looked clean I didn't do anything to them. After cleaning and oiling them it's like a whole different bike! I'd say the surging is 95% gone! I may still tweak on the air screws a little just to see what affect they have.
I'm thrilled at this point. The bike is running excellent. I fixed a small exhaust leak on the #4 header this morning. This weekend I plan on putting a few miles on it. I can't wait to get it broke in and see how it runs on top end.
- Bad Dad
13 Apr 2010 09:36 #360350
by Bad Dad
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
Replied by Bad Dad on topic *Update* Re:Jetting help with 1075
Right on ... glad it was an easy fix for ya!
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
