- Thank you received: 1
KZ650 B - something wrong with the petcock?
- TheHolk
07 Apr 2010 18:21 #359099
by TheHolk
1978 KZ650
2009 Ducati Hypermotard
1981 Vespa P200E
KZ650 B - something wrong with the petcock? was created by TheHolk
Hi,
I'm trying to rebuild a '78 KZ650 and I need some help with the petcock. Simply don't know whether this thing is broken or whether this is supposed to be like that. Looks like there is an o-ring missing, but I still can't imagine that this is not leaking...
Thanks for your help!
1978 KZ650
1981 Vespa P200E
- Thank you received: 2237
07 Apr 2010 18:41 #359107
by TexasKZ
Replied by TexasKZ on topic KZ650 B - something wrong with the petcock?
I've not had a KZ650, but on the bikes I have done this to, I just roughed up the tube with some coarse sandpaper and pressed the tube back into the petcock. No runs, drips or errors.
- rstnick
- Thank you received: 377
07 Apr 2010 18:44 #359109
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic KZ650 B - something wrong with the petcock?
I've had one come apart on my 650.
No o-ring there, just a pressed fit.
I used a bit of JB Weld on it to keep it together.
Others have used other adhesives that I can't recall.
Whatever you do, only use a bit and put it where it won't get squeezed into the petcock.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- rstnick
07 Apr 2010 18:45 #359110
by rstnick
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Oh and welcome.
Post up some pictures of the whole bike too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- JMKZHI
- Thank you received: 48
07 Apr 2010 19:29 - 07 Apr 2010 19:29 #359127
by JMKZHI
Replied by JMKZHI on topic KZ650 B - something wrong with the petcock?
A brass nipple came out of my fuel tap, so I reinstalled it w some LiquidSolder from the auto parts store - it comes in a tube w no mixing. I simply put a tad on the outside of the nipple & pressed it back into the hole.
Last edit: 07 Apr 2010 19:29 by JMKZHI.
- Bluemeanie
- Thank you received: 14
07 Apr 2010 19:54 #359137
by Bluemeanie
Replied by Bluemeanie on topic KZ650 B - something wrong with the petcock?
All the above work great but R4 turned me on to this. I tapped (1/8" pipe thread I believe) out petcock and installed a 1/4" elbow. Installed with yellow (fuel resistant) teflon tape and has worked great for past 3-4 years.
- fixer5000
- Thank you received: 5
08 Apr 2010 14:09 #359282
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic KZ650 B - something wrong with the petcock?
i used loctite ... its still on there after about 8 years
massachusetts
- TheHolk
08 Apr 2010 18:19 - 08 Apr 2010 18:21 #359356
by TheHolk
1978 KZ650
1981 Vespa P200E
Replied by TheHolk on topic KZ650 B - something wrong with the petcock?
Thanks - that helps a lot!
This is the bike. A lot of work, but that's why I bought it. Think I'll need your help again in the next couple of months. Not sure what I'm going to do with it. I plan to put it on the road first and then modify it.
1978 KZ650
1981 Vespa P200E
Last edit: 08 Apr 2010 18:21 by TheHolk. Reason: wrong pic
- TheHolk
08 Apr 2010 18:26 #359360
by TheHolk
1978 KZ650
1981 Vespa P200E
1978 KZ650
1981 Vespa P200E
- sft1662
08 Apr 2010 22:07 #359408
by sft1662
1978 KZ650 B2A
Replied by sft1662 on topic KZ650 B - something wrong with the petcock?
Looks good, I like it
Petcock is the same way on my '78 B2A. It doesnt leak but it worried me how loose it is. I'm glad other people had the same issue. I'm new here, but welcome all the same.
1978 KZ650 B2A
