z1 classic intake boots-which one?
- fandango
07 Apr 2010 11:17 #359010
by fandango
z1 classic intake boots-which one? was created by fandango
I need help please!
Here is the engine number:KZT00GE00061
I tried to order several times intake boots for it,but I always get wrong ones.(not fuel injected anymore,ports are blocked)I had kz 650 boots on it with kz 650 carbs.It did not worked well at higher rpm.My smoothbores id are bigger I had to order new boots.The z1000 boots id-s are fine but the mounting holes are much closer than on the boots.
Measurements:
mounting holes eye to eye:55mm
carb id:34
Thanks
Measurements:
carb id:34
Thanks
- OKC_Kent
- Thank you received: 20
07 Apr 2010 14:18 #359056
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic z1 classic intake boots-which one?
Did you order the boots from Z1 Enterprises? Even if you didn't I bet they would answer your question and set you up.
Oklahoma City, OK
- Jeff.Saunders
07 Apr 2010 16:12 - 07 Apr 2010 16:16 #359073
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic z1 classic intake boots-which one?
You need the KZ1000 carb holders - however, you will need to open up the mounting holes a little inward.
Use allen head screws as the pan head screws have too big a footprint and will chew into the carb holder rubber.
www.z1enterprises.com/detail.aspx?ID=2651
Z1 Ent on Facebook,
Last edit: 07 Apr 2010 16:16 by Jeff.Saunders.
