Vacuum question KZ650 w/VM26 carbs
- 2006hhr
06 Apr 2010 18:36 #358858
by 2006hhr
Vacuum question KZ650 w/VM26 carbs was created by 2006hhr
So, i installed these carbs on my bike, off either a KZ900 or 1000, dual inlets. My KZ650 had stock VM24's, single inlet. So do i need to go with a vacuum petcock off a KZ900 or 1000, or should i use the stock VM24 petcock. Just wondering if the stock one can flow enough fuel for the carbs. 2006hhr
- larrycavan
- Visitor
06 Apr 2010 18:40 #358861
by larrycavan
Replied by larrycavan on topic Vacuum question KZ650 w/VM26 carbs
Your's should work just fine. Maybe pull it out and clean out any crap that might have built up on the screen.
I just did one and it was an absolute mess.
- 2006hhr
06 Apr 2010 20:04 #358878
by 2006hhr
Replied by 2006hhr on topic Vacuum question KZ650 w/VM26 carbs
Thanks, probably what i need to do then. i just pulled the carbs apart last week and noticed the p.o. had the needle on the richest clip and stock jetting. Shooting for 20 pilots and 120 mains running a 4:1 pipe and pods. I know i would be better off with an airbox, but not sure if i can get a late 70's KZ900 or 1000 box to fit my 1979 KZ650D frame. Thanks again and will be sure to clean ou the petcock, 2006hhr
