Hesitation????
- ambassadornchains
05 Apr 2010 19:04 #358625
by ambassadornchains
Hesitation???? was created by ambassadornchains
Okay, I have 1980 kz550. I got her out a couple weeks back and everything was running great. I rode her for about a week and a half, and now I've been seeing a lot of hesitation, and don't know why. I ran some sea foam through a tank of gas and I'm still seeing it, and today I put new plugs in it (they were really sooty), and I still have it. I have gas coming out of my first carbs run off hose, like it's flooded or something. When I'm running down the road it acts fine until I really get on it in like 4th gear and up. Then just cruising it will randomly bog down. Any clue what's going on? Thanks guys
- Kawickrice
- Thank you received: 18
05 Apr 2010 19:09 #358629
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Hesitation????
Sonds like trash in the tank is working its way down. Clean out the petcock and change out the fuel filter, if its still there you will probably have to pull the carbs for a good cleaning
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- anarki650
- Thank you received: 5
05 Apr 2010 19:59 #358640
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Hesitation????
Kawickrice wrote:
+1
Also might not be a bad idea to clean your tank out real well. Pull the petcock off and make sure the screen on it isn't gunkified, and get any loose crud cleaned out of the tank so it doesn't get the chance to work it's way back into your carbs.
+1
09 Kawasaki ER6n
Omaha NE
- ambassadornchains
10 Apr 2010 19:03 #359818
Replied by ambassadornchains on topic Hesitation????
Well, I finally got a chance to check the petcock and tank and they were clean.... So, does that mean I will have to have my carbs cleaned again? I just had them cleaned and rebuilt less then a year ago, and have only put about two thousand miles on it since the rebuild (that will suck to gave to pay for that again so soon). Anyway, if you guys have any other ideas about what it could be or what I can do that would be great.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
10 Apr 2010 19:14 #359823
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Hesitation????
ambassadornchains wrote:
It is flooding. The float valve needle is not properly seating, causing the carb to overflow.
Will need to be cleaned or replaced.
Try running with your tank open to see if the tank vent isnt clogged, causing a vacuum in the fuel lines.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Motor Head
- Thank you received: 391
10 Apr 2010 19:17 #359825
by Motor Head
Replied by Motor Head on topic Hesitation????
I've got the same bike.
You may have a vacuum leak at the carb holders/ manifolds. Or its also that the float levels are incorrect, was the carbs only cleaned or rebuilt? The TK carbs are pretty simple, probably some trash working in the pilot jet/ circuit. Do you run an in line fuel filter?
You may want to also check your advancer for your ignition, these can stick. Did you sync those carbs after cleaning or rebuild?
