removing stripped screws from Diaphragm cover
- Darkangel
05 Apr 2010 11:30 #358556
by Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
removing stripped screws from Diaphragm cover was created by Darkangel
Does anyone know, how I could possibly remove stripped screws from my diaphragm cover without messing up my carbs?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
05 Apr 2010 13:17 - 05 Apr 2010 13:19 #358576
by Skyman
West Linn, OR
Replied by Skyman on topic removing stripped screws from Diaphragm cover
Are we talking BS34s?
I'd first recommend removing the carbs from the bike, if you haven't already done so (just to give you more room to work), and ideally mount them securely in a bench vise (with rags or wood strips to protect the carb bodies).
Do you have a set of screw extractors? Like these:
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40349
Basically, you drill a small pilot hole into the top of the stripped screw, then using one of these extractors, you screw it down into screw head. Since the extractor is threaded backwards, it is supposed to grip into the screw and back it out.
Can also use some penetrating oil, like "Liquid Wrench". Squirt some on the screw and let it sit for a while to soak in.
If you've got enough of the screw head to grab, and room to do it, you can grab onto it with a pair of vise grips. But move carefully. If you break off the head, then your only option may be to drill it out and re-tap the hole.
West Linn, OR
Last edit: 05 Apr 2010 13:19 by Skyman.
- Buda
05 Apr 2010 14:47 #358580
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic removing stripped screws from Diaphragm cover
If you mean the the slot of the screw (where the screw driver touches the screw) I used my dremel to make a new and bigger slot for a large flat head screw driver.
Does any of that make sense?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- JR
- Thank you received: 449
05 Apr 2010 16:36 #358586
by JR
Replied by JR on topic removing stripped screws from Diaphragm cover
I've used these before
www.aldencorporation.com/grabit/
Worked well if the screw head is still there.
- Darkangel
05 Apr 2010 18:53 #358620
by Darkangel
Replied by Darkangel on topic removing stripped screws from Diaphragm cover
yeah guys these are bs34 with philip heads on the covers, and they are stripped pretty bad.
- Kawickrice
- Thank you received: 18
05 Apr 2010 19:17 #358631
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic removing stripped screws from Diaphragm cover
JR wrote:
X2 they have not failed me yet
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Darkangel
06 Apr 2010 08:00 #358709
by Darkangel
how much do they run?
- timebomb33
- Thank you received: 10
06 Apr 2010 08:54 #358721
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic removing stripped screws from Diaphragm cover
small pair of vise grips all ways does the job for me if you can get into it or my favorite left handed drill bits but use very light to medium pressure with those you just trying to snag the screw and spin it out, not drill a hole.
