air bow removal
- chevyhead
04 Apr 2010 15:13 #358405
by chevyhead
air bow removal was created by chevyhead
i am working on my buddy's 1982 kawasaki spectrum 550 and i was wondering if i will have to remove the carbs in order to get the air box out of the way/// any advise will be very much apreciated thanks
- bigD82kzltd
06 Apr 2010 21:08 #358890
by bigD82kzltd
1982 kz1000 ltd 4 into 1 vance and hines with baffle and pod filters. stock engine that was rebuilt but don't know at how many miles
Replied by bigD82kzltd on topic air bow removal
If it is the same as my kz 1000 then yes you have to pull them.
David
David
- polkat
- Thank you received: 1
06 Apr 2010 21:13 #358891
by polkat
Replied by polkat on topic air bow removal
Yep. Usually there are two bolt holes on the sides of the box that bolt into the battery box frame. Some may be different. But there is no room to pull it with the carbs on unless you break it up with a hammer (but you'll never use it again)
