Which carbs do I have?
- Zthou1977
Due to some engine troubles I am going to clean my carbs. Because I will be boiling them in a lemon juice/water mixture, I will need new gaskets. Trouble is, I am not sure which carbs I have. The bike is a 1977 Z650B1, which should have either Mikuni VM22SS (Kawasaki manual) or VM24SS (Haynes manual).
Measuring the inner diameter of the carbs exits, I get about 26mm (25.8-something). Doesn't that mean I have VM26's?
If so, how should these be jetted? I use the standard airbox/filter and a Marshall 4-1 that (according to the factory) does not need rejetting.
Thanks!
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
- Nebr_Rex
- Thank you received: 300
Hi all,
Thanks!
did you measure the inside diameter on the cylinder head side?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Zthou1977
Yes, it is about 26 mm (25.8 or so). Strange thing is, I have a later set of Mikuni carbs (with a different kind (stump instead of sharp) and position (diagonal on the side instead of at the bottom) of the pilots). This later set also measures about 26mm on the inside diameter on the cylinder head side. These were sold to me as a set of late-model Z650 carbs.
- Mcdroid
- Gone Kwackers
- Thank you received: 319
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
- Thank you received: 48
The VM24 carbs measure ~26mm at the engine side opening, but 24mm near the slides on either side.
- Bluemeanie
- Thank you received: 14
- Zthou1977
I just tried to measure the inside diameter at the slide. But because I only have a slide caliper that cannot quite reach there, I had to align it by eye. Best guesstimate is that the diameter at the slide is 22mm. It is also the most likely, as the Kawa manual says so. I cannot measure the newer set, as I put these on the bike yesterday.
All of this started because it would only run on three cylinders. With the newer carbs (which are spotless inside, and with the vacuum line capped) the bike wouldn't even run.
Guess I'll have to order 4 carb kits and wait. Not a problem right now, as I can only work on the bike between the downpours. Ghastly weather here.
@ Bleumeanie:
The carbs have three ribs, like yours.
Thanks for the replies everyone!
- Old Man Rock
- Thank you received: 225
www.z1enterprises.com/reference/z1-carb-guide.aspx
Carb Theory and tuning manuals...
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- rstnick
- Thank you received: 377
Find the largest one that matches the fit up to the slide, then measure the outside diameter of the socket.
Both VM22SS & VM24SS carbs have the 3 ribs IIRC.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- RonKZ650
- Thank you received: 240
- JMKZHI
I simply cut a piece of stiff cardboard to 24mm then use that as a measuring device.@ JMKZHI:
I just tried to measure the inside diameter at the slide. But because I only have a slide caliper that cannot quite reach there, I had to align it by eye....
