81 kz 550 running lean
- shizzomynizzo
02 Apr 2010 18:56 #358026
by shizzomynizzo
24 hours in a day...24 beers in a case
1981 KZ550 ***SOLD***
1982 KZ1100 A2
81 kz 550 running lean was created by shizzomynizzo
I have an 81 550 that is running very good. No problems starting, no idling problems, accelerates good, too.
Anyway I pulled the plugs and they are a little whiter than I would like. They are a mix between tan and white, but more white. I hear these horror stories of people who burn holes in their pistons from running lean, too long.
Is it normal to have a little white on these plugs, or should I rejet?
I just acquired the bike a few months back and am only riding it for the first time this past month. Stock airbox and exhaust.
Also whih way do I tuen the adjustment screws to make it richer?
Thanks,
Shizz
Thanks,
Shizz
1982 KZ1100 A2
- TeK9iNe
- What did you do!?!
- Thank you received: 28
03 Apr 2010 08:47 #358146
by TeK9iNe
Don't touch it! :laugh: if your putting a hole in a piston, you will see/hear evidence of it, aluminum specks melted to the ceramic of the plugs and ping/knocking of the engine.
A little whitish is fine. You can play with the jetting if you like, but remember its about power and delivery. If it feels good, it usually is. You can fiddle with things to try and make it better, if that doesnt work go back.
Being a little lean is fine, especially in cooler weather.
If this infact your carb, then the air screw on the side is precisely that - out = more air into pilot circuit, in = less.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 81 kz 550 running lean
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- shizzomynizzo
03 Apr 2010 11:32 #358175
by shizzomynizzo
1982 KZ1100 A2
Replied by shizzomynizzo on topic 81 kz 550 running lean
Thanks for the input.
1982 KZ1100 A2
