hesitation under 4k rpms
- comppro2k7
01 Apr 2010 22:23 - 01 Apr 2010 22:24 #357852
by comppro2k7
hesitation under 4k rpms was created by comppro2k7
i have a 83 kz750-n2 the bike has a hesitation anything under 4k rpms, once it hits 4500 rpms and up its a rocket, and very smooth. It feels like turbo lag on a car, if you easy the throttle is decent acceleration but if you got WOT theres lag until 4500rpms. Ive cleaned the carbs, has new carb intake boots that goes from head to carb,new plugs. any suggestions ? possibly carbs out of sync or something? any help would be appreciated. thanks
Last edit: 01 Apr 2010 22:24 by comppro2k7.
- Old Man Rock
- Thank you received: 225
02 Apr 2010 04:57 #357884
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic hesitation under 4k rpms
First thought to come to mind is Needle/clip position on the lean side....
Pre-carb cleaning, did this condition exist?
Have you synced the carbs recently?
Have you just recently switched over to different exhaust, pods or something else?
What are your plugs telling you?
Meaning, condition, rich, lean, sooty, oily etc...
Ignition timing spot on?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
- Thank you received: 337
02 Apr 2010 16:41 #357999
by bountyhunter
Replied by bountyhunter on topic hesitation under 4k rpms
Running pods or low restriction baffle in the muffler? That will make it run lean.
- comppro2k7
02 Apr 2010 22:10 - 02 Apr 2010 22:11 #358056
by comppro2k7
Replied by comppro2k7 on topic hesitation under 4k rpms
the bike is all stock, only 7400 miles on it, never modified, so im guessing the carbs have never been re synced,ran the same before the carbs were cleaned. Will pull a plug and see what it looks like.
Last edit: 02 Apr 2010 22:11 by comppro2k7.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
03 Apr 2010 08:28 #358142
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic hesitation under 4k rpms
Remember, everything from airbox to exhaust has to be air tight.
Clean air filter.
Seafoam!
mixture screws,
sync carbs,
timing.
Clean air filter.
Seafoam!
mixture screws,
sync carbs,
timing.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
