wide open
- eyeofthestorm
- its KZ kraziness!
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
Did you do a plug chop at WOT before reading the plugs? That's the only way to accurately assess the main jets.
West Linn, OR
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- Old Man Rock
- Thank you received: 225
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
Unless other issues, seems like Mains jet is still too lean....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- eyeofthestorm
- its KZ kraziness!
i havent run it right up to WOT and checked, but i did run it at highway speed for a few miles, bout 70-75mph, and then took the reading from that, its definantly running off the mains at that speed, ive been told that the pilot jets in the carbs on my bike do little more than idle.
- eyeofthestorm
- its KZ kraziness!
my mains should be okay, i might give each of the adjusting screws one half turn to be safe. i cant see it being too ornery, since its been running fine with just main jets up for a while, and not much adjustment is needed, if any at all, since im riding it in the blistering cold the last few weeks i figure thats gonna have the most to do with why my mixture is lean, so a slight adjustment to the mid and lower range, and i figure shes golden. i love how easy these carbs are to deal with.
- roy-b-boy-b
- Thank you received: 103
- nads.com
- Thank you received: 20
- eyeofthestorm
- its KZ kraziness!
anyways, so i gave my pilot jet needle screws one half turn in, and actually managed to get out on a warm-ish day, 15-18*c here this afternoon, and went for a nice hard burn down the highway, to reveal a nice, rich, caramel brown plug in each cylinder. so im happy. dont have to screw with the needles, thank god. synced her up, shes ready to groove. i reckon my assumption was right all along, it was the cold leaning her out on me, and when the average temps slide up to the mid 20's i can probably jet down to a 120 main again.
thanks for all the help and info guys, shes good for the season now, hopefully for good, at least as far as carbs are concerned.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Its not running off the mains until you open the throttle beyond 2/3. The speed your travelling at has nothing to do with it. The rpm also has very little to do with it.
The fuel circuit/jet that is used is dependent on the throttle input.
You wont know if you have a correct main jet without doing a WOT plug chop.
Get the bike into top gear really early, then crack it FULL. When you get to just over half of max rpm, KILL SWITCH the engine while still holding the throttle open.
Pull clutch in quickly at same time, then stop and look at the plugs.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
