'77 KZ 1000 jets
- moffy
'77 KZ 1000 LTD, '07 R6s
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- roy-b-boy-b
- Thank you received: 103
And Welcome. Stick around and you will be the KZ Guru. Roy
- michikawi
Norm
- keith1
- Thank you received: 2
check your float heights the jetting sounds pretty close to what i use myself and mine works fine it sounds to me like you have some bad float valve assemblies. i also use pods and have a very free flowing exhaust. it definitly dosent sound like a jetting problem to me.
what tim said......
- moffy
- michikawi
Get a good manual, Kawasaki if you can find it, and go through a tune up, step by step, keeping in mind yu will be running bigger jets than stock because of your more free flowing set up.
Good luck.
Norm
- bountyhunter
- Thank you received: 337
I maintain that standard every six month maintenance procedure is to take the float assemblies out. Not just to clean, but I put the needles in a hand drill and polish the tapered ends with #600 paper until they are dead smooth. I put the brass seats in and use a Q Tip and crome polishe to shine up the inside where the needle goes. Once you get them sealing tight you have no gas seepage problems.Thanks for the help! I'll double check the float valves,
