Re-fitting petcock back on gas tank?
- Tommotbird
28 Mar 2010 07:18 #356683
by Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Re-fitting petcock back on gas tank? was created by Tommotbird
Just wondered if any of you guys use any gasproof mastic when re-fitting a petcock back on a gas tank. Is a new O ring as supplied with a petcock repair kit usually sufficient on its own.
Tommotbird
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
28 Mar 2010 11:18 #356731
by Skyman
West Linn, OR
Replied by Skyman on topic Re-fitting petcock back on gas tank?
Are you talking about the bolt-on style of petcock with the oval o-ring?
If so, I've just relied on the o-ring with out any additional sealer, and it has worked fine.
West Linn, OR
- paulstanely45
- 1977 KZ650-B
29 Mar 2010 15:01 #356988
by paulstanely45
1977 KZ650-B
Replied by paulstanely45 on topic Re-fitting petcock back on gas tank?
Usually the o-ring and bolts work just fine, but if youre like me, and a bit paranoid, there is a tube of stuff you can get called "Seal-All" and its pretty much impervious to gasoline. It dries quick though!
1977 KZ650-B
- RonKZ650
- Thank you received: 240
29 Mar 2010 19:35 #357082
by RonKZ650
Replied by RonKZ650 on topic Re-fitting petcock back on gas tank?
Orings work if new, but if for some reason the petcock ever needs to be removed, reusing the old oring will leak every time. For this you can seal with Yamabond #4 or equiv. I rarely replace the ring, just put a little Yamabond on the existing ring and no leaks. The mount bolts with the plastic washers never leak, just the oval ring.
- Thank you received: 2829
30 Mar 2010 07:44 #357179
by 650ed
Replied by 650ed on topic Re-fitting petcock back on gas tank?
As long as you have a new o-ring you won't need sealant. If you reuse an old o-ring that is deformed it will leak unless you use sealant. I bought a couple extra o-rings while they were avaialble and cheap to avoid the problem in the future. Ed
