Carb Tubes
- sft1662
Also --- Does anyone know of the size of clear tubing that is needed for the clear tube float level test? and how to attach it to the drain hole without the "special kawasaki tool" that is shown in the manual?
Finally --- Are there any gaskets that normally need replacing during a carb cleaning?
Thanks
-Image courtesy of a post that I found...
1978 KZ650 B2A
- JR
- Thank you received: 449
- Bluemeanie
- Thank you received: 14
First --- Does anyone have the sizes and/or a source of the different tubes for the big vents, small vents, and fuel line? Any recommendations for a good in-line fuel filter, I have one but am going to replace it when I work on my carbs and I also want to replace all the old/crusty/stiff fuel and vent lines while I'm at it.
These are metric sizes but I've had good luck with 1/4" fuel line.
Instead of figuring out what size tubing to jam into carb just get one of these. Works fantastic!
I bought kits when I did mine but generally you don't have to replace any gaskets if in good shape. But kits will have new needle and seats for fuel bowl which might be leaking.
- sft1662
thanks again
1978 KZ650 B2A
