- Thank you received: 88
runs on full choke only
- GregZ
21 Mar 2010 13:21 #355205
by GregZ
runs on full choke only was created by GregZ
Tried starting the 900 motor after new top end,rings valve job.
new to me 28mm carbs were eBay item. I complelty cleaned and installed correct stock jets.
Bike starts seems to run good but will not run when you take it off full choke,instintly shuts down when you start to take it off choke
any advice appreciatied
- otakar
21 Mar 2010 13:55 #355219
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic runs on full choke only
Raise the idle setting.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- GregZ
21 Mar 2010 20:42 #355329
by GregZ
Replied by GregZ on topic runs on full choke only
tried that nothing full choke or nothing I have no idea
- baldy110
- Thank you received: 512
21 Mar 2010 21:14 #355336
by baldy110
Replied by baldy110 on topic runs on full choke only
Dirty Idle circuit, re-clean the carbs
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
21 Mar 2010 21:24 #355338
by Skyman
West Linn, OR
Replied by Skyman on topic runs on full choke only
Yep, sounds like you've got a blockage in your idle circuit.
I had a similar problem, and discovered that the problem was being caused because I forgot to remove one of the die-cut punch-outs on new float bowl gaskets I installed. This blocked one of the passages for the idle circuit. After removing the punch-out, it worked fine.
West Linn, OR
- Thank you received: 2098
21 Mar 2010 21:38 - 21 Mar 2010 21:39 #355340
by Patton
Replied by Patton on topic runs on full choke only
Last edit: 21 Mar 2010 21:39 by Patton.
- GregZ
22 Mar 2010 06:22 #355358
by GregZ
thanks for the tip. Now I need to make sure I have the correct pilots. Long barrel or short barrel ??
