Best Jets for '79 KZ1000 E-1 with K&N Pods?
- onanysunday
21 Mar 2010 11:29 #355185
by onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
Best Jets for '79 KZ1000 E-1 with K&N Pods? was created by onanysunday
I have a '79 KZ1000 E-1 (VM28SS carbs)that was jetted for 6,500+ feet with stock exhaust. Now at sea-level, the bike is not running as good. It has become harder to start and now "bogs down" in 1st gear when accelerating off a full stop to the point it almost kills.
The carburetors were recently cleaned and valves adjusted last fall before the bike was winterized. Engine runs rich and fouls sparkplugs. Given my setup with PODS and stock exhaust, what main jets, pilot jets and jet needles would give the best performance for sea-level riding? I could replace these myself but have no idea which ones to get because having pod filters is supposed to change jet requirements (from stock)
Also, does having pods mean that every carburetor(s) air screw has to be adjusted differently to achieve the same lean/rich idling mixture as the other carbs? I've been having a hard time dialing in my lean/rich mixture with pods as evidenced by constantly "reading the plugs" and finding some cylinders run a lot richer than others.
79 KZ1000 E-1
VM28SS
K&N Pods
- Nebr_Rex
- Thank you received: 300
21 Mar 2010 11:43 #355190
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Best Jets for '79 KZ1000 E-1 with K&N Pods?
stock is 15 pilots,110 mains,e-clip at middle or 3rd slot
I'm at 1200 ft.turbo cams degreed at 105/109 and 10 to 1 pistons with 17.5 pilots and stock replacement K&N,otherwise stock
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- onanysunday
21 Mar 2010 12:37 #355197
by onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
Replied by onanysunday on topic Best Jets for '79 KZ1000 E-1 with K&N Pods?
I thought I had to use different jet sizes with pods because they suck more air than stock.
79 KZ1000 E-1
VM28SS
K&N Pods
- Nebr_Rex
21 Mar 2010 18:40 #355312
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
onanysunday wrote:
pods do not suck air
you are still running the stock exhaust.I suggest finding someone who knows what they are doing rebuild the carbs back to stock but use 17.5 pilots and maybe raise the needles one notch
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
