Kz550 High Idle after reassembly
- cccampbe
19 Mar 2010 12:16 #354566
by cccampbe
Kz550 High Idle after reassembly was created by cccampbe
I recently took my 1984 kz550 down to bare frame and cleaned it up, change the head and valve gaskets. In the last few days I have gotten it back together and have been trying to get it running. Figuring out the vacuum system took a while but I finally got it hooked up correctly i think. The bike fires every time now but it is idleing at 4k. I tried adjusting it with the idle knob but can only get it to go higher, not any lower than 4k. I was hoping to be able to ride it tomorrow so any help would be appreciated. Thanks in advance. I did search but couldn't find the answer i need.
- otakar
19 Mar 2010 12:33 #354570
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Kz550 High Idle after reassembly
You must have a LARGE vacuum leak in most likely all four carbs. IE you do not have the vacuum lines hooked up right.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
- Thank you received: 1616
20 Mar 2010 23:26 #355089
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Kz550 High Idle after reassembly
If it seems to run normal, (no popping or erratice revving), it may also just be the throttle cable is hanging up. Make sure all of the junctions in the cable housing are fully seated. Also make sure there is some slack in the cable (and freeplay on the throttle) when the throttle is closed.
With all the work you did, soemthing may have happened to the cable.
1981 KZ550 D1 gpz.
Other links.
- savillian
14 Jun 2011 22:25 #457312
by savillian
Replied by savillian on topic Kz550 High Idle after reassembly
So sorry to pull up a very old and dead thread, but I am wondering if you ever did find a solution?
I am a new KZ550 owner that had a great running bike....Until I filled the fuel tank. Now it does exactly a yours did and idles @ approx. 4K RPM.
I have looked at the idle knob, all the boots, etc. The only thing I could figure is there is a problem with the vacuum diaphragm as it was running great on reserve with a little bit of fuel in the tank.
Thanks
Thanks
