why
- live2ryde88
18 Mar 2010 19:01 #354395
by live2ryde88
why was created by live2ryde88
why do i not have any free play in my throttle control? how to fix?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
18 Mar 2010 19:05 #354396
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic why
What bike?
Check to ensure slack at the carbs, and at the throttle itself.
Its usually a case of just loosening a nut, then spinning the other until desired play is achieved, then retightening first nut. At both ends...
GL
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- live2ryde88
18 Mar 2010 19:10 #354398
by live2ryde88
Replied by live2ryde88 on topic why
well i gotta be doing something wrong. i have a 76 kz400. ok well when i hook on the cables to carbs . then i twist throttle the throttle control just seems tight i mean when i give it gas there is no play at all . when i move throttle it rite away gives it gas. there is no slack at all.. and it idles at 3000 rpm. and i have no vac leaks
- TeK9iNe
18 Mar 2010 19:21 - 18 Mar 2010 19:26 #354400
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
OK. the slack is adjustable at the handle also.
Do you have FSM? Manual? Should be pretty clear in there.
You should be able to put as much slack as you want to at the handle just by playing with the nuts, almost just like a bicycle.
Just play witht them, you'll get it. Or take it completely apart, then re-assemble. Pretty easy...
Adjust your idle screw out to drop rpms. If that doesnt work, then its the throttle hanging up the rpms.
OR... Disconnect the throttle cable from the carbs completely, and start the bike. If still idles high, then turn out idle screw all the way. If still idles high, may be vacuum leak or slides are not properly adjusted/sticking.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 18 Mar 2010 19:26 by TeK9iNe.
- TeK9iNe
18 Mar 2010 19:30 #354401
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
18 Mar 2010 19:30 #354402
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
18 Mar 2010 19:31 #354403
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
#24 in first pic is idle adjust screw.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
18 Mar 2010 19:43 #354406
by Patton
18 Mar 2010 19:49 - 18 Mar 2010 19:51 #354408
by Patton
Replied by Patton on topic why
If not already done, would also assure smooth cable curves and routing between throttle grip and carbs, especially along frame tube under fuel tank, to prevent kinks and sharp turns from impairing smooth complete cable action.
New throttle cables might be needed.
Last edit: 18 Mar 2010 19:51 by Patton.
- TeK9iNe
18 Mar 2010 20:17 #354426
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Patton you devil.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
