help with idle
- live2ryde88
18 Mar 2010 16:26 #354363
by live2ryde88
help with idle was created by live2ryde88
bike is idling at about 3000 rpm... i have no freeplay in the throttle ? what am i doin wrong? what do i need to do?
- Kawickrice
- Thank you received: 18
18 Mar 2010 16:40 #354365
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic help with idle
Is the large thumb screw on the carb adjusted right. If all the adjustments are right I would look for a vacuum leak, use some carb cleaner and spray it all around the carb holders if the rpm's rise higher you have found the leak
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- live2ryde88
18 Mar 2010 16:43 #354366
by live2ryde88
Replied by live2ryde88 on topic help with idle
not sure what u mean by big thumb screw
- Kawickrice
18 Mar 2010 16:59 #354375
by Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
live2ryde88 wrote:
Where the cables hook to the carbs you should see an adjuster screw that you use your fingers to loosen or tighten, it should have a spring on the shoulder of the screw. The butterfly looking part that the cables hook to should have the stop screw.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
