Trying to jet a carb for the first time
- grizlywinkleman
16 Mar 2010 16:19 #353903
by grizlywinkleman
Trying to jet a carb for the first time was created by grizlywinkleman
I own a '83 kz750 ltd (twin). I put pod filters on it and it doesn't run right. It idles better but when I give it gas it bogs and backfires. I tryed to follow my friends guidence to adjust the jet needles but I only have one slot on mine. So I need to know if I need to replace my pilot jet or main jet. And what size I would roughly need. My Pilot jets have #45 on them and my main jets have none.
Any assisstance from anyone would be greatly appreciated.
Thanks much,
Ryan
Thanks much,
Ryan
- TeK9iNe
- What did you do!?!
- Thank you received: 28
16 Mar 2010 18:05 - 16 Mar 2010 18:08 #353924
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Trying to jet a carb for the first time
Start with this, it works OK at best:
Jetting Guide
You will need to buy several sets of Main jets, in order to find the ones that give you the best power delivery and response.
Its going to take alot of patience.
Only change one circuit at a time! Then test...
Good Luck!
Jetting Guide
Good Luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 16 Mar 2010 18:08 by TeK9iNe.
