Is my problems Carbs or what??
- jrmc43
15 Mar 2010 16:01 #353688
by jrmc43
Is my problems Carbs or what?? was created by jrmc43
Hope someone here can help me. I have a 75 900Z1 that I'm in the process of restoring. Problem I'm having is kinda strange. Bike starts fine, idles fine after warm up. When I ride it has good power in first gear but starts stalling from 2nd gear on. If I open the choke bike runs great. Runs a bit better but not great when motor completely warms up. Naturally I have to turn the choke off when I pull up to a stop light or else it dies. Hope someone can be of some help. Thanks
- keith1
- Thank you received: 2
15 Mar 2010 16:15 #353691
by keith1
Replied by keith1 on topic Is my problems Carbs or what??
float heights correct?
- mastermudd
15 Mar 2010 16:19 #353692
by mastermudd
Replied by mastermudd on topic Is my problems Carbs or what??
had a 76 kz650 a few years ago that did something similar. oddly enough if i took the air filter out (and yes i did try a new one) it ran like a scalded dog, but would bog way down and hardly run if the filter was in.
- otakar
16 Mar 2010 06:57 #353801
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Is my problems Carbs or what??
This can be carburetors or bad compression. Do a compression check first. That way you don't have to tear anything apart. If you find the compression OK, check that you have a strong spark. That can also cause these symptoms. If you have a strong spark than tear the carbs apart and do an overhaul. You do not have to pull the slides, just do the lower part of the carbs. Pay special attention to the system (Improperly called the choke) and all the air and fuel jets.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kawickrice
- Thank you received: 18
16 Mar 2010 07:29 #353807
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Is my problems Carbs or what??
Sounds like you need to pull the carbs and clean them again. It has taken me 4 times before I got them right.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
16 Mar 2010 07:48 #353817
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Before you pull anything, do the prescribed checks. It will save you a lot of time in the long-run. These checks will only take you about 15-20 minutes. It will be time well spent and it will give you a decent look at the overall health of the engine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
16 Mar 2010 12:51 - 16 Mar 2010 12:55 #353878
by Patton
Replied by Patton on topic Is my problems Carbs or what??
mastermudd wrote:
Symptom with throttle 3/4~wot --- Possibly main jets too large, thereby running better with more air from airbox absent filter, and worse with less air when restricted by filter;
Symptom with throttle at 1/4~3/4 --- Possibly clips on the jet needles are too low (raising needles too high), and resulting in excessively rich mid-range, thereby running better with more air from airbox absent filter, and worse with less air when restricted by filter.
Last edit: 16 Mar 2010 12:55 by Patton.
