- Thank you received: 10
gsxr flat slides
- timebomb33
13 Mar 2010 20:36 #353191
by timebomb33
I THINK MY POWERBAND BROKE
gsxr flat slides was created by timebomb33
i just got done innstalling a set of early model(85-86) flat slide carbs from a gsxr 750 onto my little drag bike(1015cc). they have been bored out to 33.5 mm i used the intake manifolds and velocity stacks that came with the carbs these carbs had been converted to center pull from the original rightside throttle. i put in a 125 main and after i played around with the accelorator pump settings abit it started on the second kick man do they rock they feel way stronger then my 29 smoothies i'll find out next weekend when i do some dyno runs last year with the 29's it made 112 horsepower i'm betting more this year it is the same exact engine just adjusted the valves. so it will be agood test for them. going off seat of the pants feel and how many gears it spun thru though i definitly feels stronger yee ha. i'll keep you posted
- larrycavan
- Visitor
13 Mar 2010 21:19 #353201
by larrycavan
Replied by larrycavan on topic gsxr flat slides
Way to go Tim!
What cams are you running and what compression?
- trianglelaguna
- Thank you received: 235
14 Mar 2010 06:57 #353250
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic gsxr flat slides
they sure were drooling over those carbs when they first got released and were a reference carb for what a carb should pull like for yrs...good work converting them....nice rack of carbs....may be a new upgrade for folks here to consider....will they street ride???any issues???let us know...
1976 KZ900
2003 ZX12R
2007 FZ1000
- Kawickrice
- Thank you received: 18
14 Mar 2010 07:48 #353262
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic gsxr flat slides
My brother has 2 86 GSXR 750's and he is having a rough time tweaking the carbs. The previous owner butched up the plastic emultion tubes for the needle. Did you have a problem like that?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Old Man Rock
- Thank you received: 225
14 Mar 2010 08:02 #353267
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic gsxr flat slides
Timmy, please post the Dyno chart run?
Way cool!
OMR
Way cool!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
14 Mar 2010 10:42 #353306
by timebomb33
Replied by timebomb33 on topic gsxr flat slides
will post the run if i can figure out how. larry i have a set of 12-1 mtc's stock 1000 bore by the way really old mtc'sas near as i can tell around 1982 vintage a mk 11 head that is mildly ported it's definitlty not one of my better heads stock valve sizing and a set of .395 web cams that i have been running in pretty much evrything since 1996 it's real good working combo. in calgary i ran 10.60's 3700ft or more depending on the day. consistently and in mission b.c sea level,i have gone as quick as 10.20's with this combo so it works pretty well i'm planning on swaping heads out with a big valve setup that i have run down in the 9's with but i've been lazy i just fiished and two other heads for a couple of big blocks so, maybe after the dyno runs maybe i'll swap the valve job does need touching up.
- timebomb33
14 Mar 2010 10:47 #353308
by timebomb33
kawickrice i didn't have any problems at all with these carbs in fact i was amazed at how good they worked right out of the box in fact i have 2 more sets and i think i'm going to convert them both to center pull and put them up for sale i know how to do it so look out i will be looking for those carbs for sure again. and craig i know they would make excellent street carbs once they are set up they seem to do everything well.
