carbs
- triggerman
13 Mar 2010 20:16 #353186
by triggerman
carbs was created by triggerman
i just go a 81 kz1000csr carbs were dirty cleaned them... so i think... im still not getting any fuel in the cylinders the bike hasnt been started in like 3 or 4 years some of the vaccum lines that are on the carbs look kinda cheesy there is a hose the goes from carb 1 to carb 4 one from carb 2 that goes to the (petcock) and carb 3 has a plug on the vaccum (outlet) and the repair manual that i have does say anything about that and the pics dont show it either... can anyone help me?
- bountyhunter
- Thank you received: 337
13 Mar 2010 20:56 #353197
by bountyhunter
Replied by bountyhunter on topic carbs
A vacuum operated petcock will shut the fuel off completely if it does not have vacuum on the port that operates the cutoff. The auto cut off is to prevent gas leaks when the engine is off.
- triggerman
14 Mar 2010 06:52 #353248
by triggerman
Replied by triggerman on topic carbs
wut is the best thing that i could use to clean the diaphram? i was told not to use break or carb cleaner but i was not told wut would work...?
- otakar
14 Mar 2010 08:23 #353275
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic carbs
If you are referring to the diaphragm in the carburetors, just use some furniture polish.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
