what stock carb jet size
- terry s
12 Mar 2010 10:16
I have a 1980 LTD 1000 and am going to attack my carb. again. When I had it apart last summer I couldn't find the jet size numbers on them. So I guess I will put new jets in. I have the stock jardines and the stock airbox on it. What jet size do you guys suggest? This bike is fouling plugs every 100 miles or so. The voltage on the coils was 11.3 and I just fixed that problem. I have my doudts if that was my problem.
- otakar
Re: what stock carb jet size
12 Mar 2010 11:26 - 12 Mar 2010 11:29
The specifications for those carbs with all the jetting is in your maintenance manual. If they are 28mm like on the 1980 ST model than the stock jet size is 110 with 112.5 being the recommended alternate. If they are 26mm than the mains are most likely 105 or 107.5 But since you ride at only partial open throttle at most times the main jets have nothing to do with your fowling. You have other problems.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 12 Mar 2010 11:29 by otakar.
- TeK9iNe
- What did you do!?!
12 Mar 2010 11:53
The voltage @ your coils is only really important while you're driving down the road... probly havn't tried that huh? :laugh:
Old wiring and regulator/rectifiers can do strange things.
Make sure your compression is good.
The coils being at 11.* , can contribute to fouling with an old tired engine.
They should be at 13+ when running.
When all else fails, changing jets is ok, but exhaust the simple stuff first.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
