- Thank you received: 3
carb issue
- Kawiman80
- On my 2nd KZ1000
11 Mar 2010 23:01 #352841
by Kawiman80
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
carb issue was created by Kawiman80
Hey guys,
My buddy just bought a 1987 ZX1000 and is having trobles with the carbs. I am not that familiar that year of bike,so I am asking you for some help to relay to him.
The problem is: the bike will run at idle and rev to around 6,000 and cut off,then back to idle. It has 36mm Keihin carbs on it and he says there is a vacuum piece or pieces that my need to be replaced. Somewhere around 100 bucks a pop!! If you can give any insight to this,please give all you can. It is his first street bike so he really wants to do the work himself,that way he knows about his bike.
Thanks,
Mike
Thanks,
Mike
- Thank you received: 2237
12 Mar 2010 17:26 #352981
by TexasKZ
Replied by TexasKZ on topic carb issue
Sounds like it could be torn diaphragms. If so, replacement is generally the best option. Yes, they are expensive. If this is the problem, then it is very likely that some ham-fisted goober has been in the carbs, so there is no telling what else could be going on in there. Good luck.
