Vaccum Line question
  • AzKZ650
  • AzKZ650's Avatar Topic Author
29 Mar 2006 14:47
#35258
Hi Folks,
I'm really new at working on motorcycles and I could use some help with my carbs vaccum ports. I have a 1978 KZ650 SR, and I have to open ports here:
  • AzKZ650
Re: Vaccum Line question
29 Mar 2006 14:48
#35259
Damn, mixed that up. that would be 4 open ports in first pic and 2 in this pic.
Should I have lines running to them or block them off ?
  • btchalice
  • btchalice's Avatar
29 Mar 2006 14:49
#35260
those are overflow tubes you need 4 short hoses to drain below the bike in the event of an overflow so gas doesnt land on a potentially hot engine
oops posted on the first pic
the two in the second usually tee into the vaccuum valve on a petcock not sure on your bike though
Post edited by: btchalice, at: 2006/03/29 17:52
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • AzKZ650
29 Mar 2006 14:51
#35262
Sorry about the supe-sized pic, thought I had reduced it.
  • AzKZ650
29 Mar 2006 22:07
#35360
Hi btchalice,
Do you think I should try and re-run some lines to connect the top two with the petcock, or just cap them since the bike runs as is ?
Thanks,
-Brian
  • NOS
  • NOS's Avatar
30 Mar 2006 03:47
#35384
As far as I know only one line runs the vac on the petcock. I may be wrong on this, but the two lines could be for the "clean air" system. Seems like you could cap them off and see if everything works OK. If they were vac lines, the petcock wouldn't work at all when set "on" or "res", (if the petcock was working properly :unsure: )it would only flow without vaccum on "prime". (at least on my bikes)
To determine if you have a vaccum petcock you need to look at its settings. On vaccum models there are "on","Res", and "Prime". Non-Vac Petcocks, I believe, have "On", "Res, and "off".
Check to see what petcock you have and that should determine what the lines are for.
BTW, could you post a supersize pic of the 2 lines (my eyes aren't as good as they used to be ;) )
Post edited by: NOS, at: 2006/03/30 06:49
  • wiredgeorge
  • wiredgeorge's Avatar
30 Mar 2006 06:47
#35415
This link contains info on connecting your carburetors:
www.wgcarbs.com/88724.html
  • AzKZ650
30 Mar 2006 10:48
#35453
Thanks wiredgeorge, that page is Great !!! and NOS thanks for explaining the different petcocks, mine is a vaccum operated one.
Thank You,
-Brian
