- Thank you received: 1616
kz550 A2 stalls on highway run
- loudhvx
09 Mar 2010 12:04 - 09 Mar 2010 12:08 #352225
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic kz550 A2 stalls on highway run
Also, even though the petrcock takes a key, it is not "keyed". Pretty much any key that fits in far enough will open it.
I doubt it's a float level issue. That would show up anytime you were accelerating hard. Because it's a sustained speed issue, I think others had it right, it's a fuel delivery issue.
Have you taken the petcock out of the tank and inspected the internal screen filter as GPZ550D1 suggested?
Also, don't use an inline paper car filter. Those have been problematic.
As was mentioned, rule out the tank vent as a possibility.
1981 KZ550 D1 gpz.
Other links.
Last edit: 09 Mar 2010 12:08 by loudhvx.
- shizzomynizzo
09 Mar 2010 18:20 #352318
by shizzomynizzo
24 hours in a day...24 beers in a case
1981 KZ550 ***SOLD***
1982 KZ1100 A2
Replied by shizzomynizzo on topic kz550 A2 stalls on highway run
Well i drove it today on the highway with the cap open and the problem was gone. There is some kind of build up where the vent hole is. I am going to take it apart tomorrow and give it a good cleaning.
On another note, the petcock does not turn off. I pulled the fuel line off and it never shut off. It flows the most on prime, but still comes out on res and on.
Will cleaning the petcock fix this, or do I need a rebuild kit? I am new to vacuum petcocks.
Thanks again
Thanks again
1982 KZ1100 A2
- loudhvx
09 Mar 2010 23:24 #352364
by loudhvx
1981 KZ550 D1 gpz.
Other links.
You probably need the rubber seal for the inside of the lever assembly. That's the round part that has four holes in it. I don't think I've seen them available separately, but they do come in the rebuild kits.
(It should turn off in "on" or "res" position with the engine stopped.)
1981 KZ550 D1 gpz.
Other links.
- Thank you received: 2098
10 Mar 2010 05:16 - 10 Mar 2010 05:17 #352388
by Patton
Replied by Patton on topic kz550 A2 stalls on highway run
shizzomynizzo wrote:
Would disassemble, inspect, and carefully clean.
Might find grit or crud impairing the diaphragm action, 0-ring, spring, or position gasket.
But the diaphragm or 0-ring or gasket may be damaged beyond further service.
If parts look okay, reassemble and see what happens.
...petcock does not turn off. I pulled the fuel line off and it never shut off. It flows the most on prime, but still comes out on res and on.
Will cleaning the petcock fix this, or do I need a rebuild kit? I am new to vacuum petcocks....
Last edit: 10 Mar 2010 05:17 by Patton.
- shizzomynizzo
10 Mar 2010 06:13 #352399
by shizzomynizzo
1982 KZ1100 A2
I'm going to try and run most of the gas out before I remove the tank and tinker with the petcock. The inside of the tank is spotless, but I'm sure there is some build up of crap on the screen.
I looked at the bike after I was done riding it and there was a puddle of gas below it. The #3 carb started spewing gas and it has not done this before. I tried tapping it with a screw driver, to no avail. I loosened the screw to empty the bowl, let it fill and emptied it a few more times and it stopped. I hope I don't have to remove the carbs again, they are a real PITA!! well at least compared to my honda.
Thanks for all the help guys!
1982 KZ1100 A2
10 Mar 2010 09:30 #352437
by Patton
Sounds like were able to flush away whatever grit or crud was impairing the float valve function.
Hoping an inline fuel filter is fitted.
- shizzomynizzo
10 Mar 2010 20:27 - 10 Mar 2010 20:28 #352590
by shizzomynizzo
1982 KZ1100 A2
1982 KZ1100 A2
Last edit: 10 Mar 2010 20:28 by shizzomynizzo. Reason: duplicate post
