- Thank you received: 1616
Gpz550 can't accelerate at full throttle
- vector86
- Visitor
07 Mar 2010 18:41 - 07 Mar 2010 18:45 #351855
by vector86
Gpz550 can't accelerate at full throttle was created by vector86
I recently bought this bike from a friend who says it has a stage 3 jet kit made by dynojet. The bike starts and idles fine but when I go full throttle the engine only accelerates to about 6k rpm and won't accelerate anymore unless I drop back to about 1/2 throttle. When I checked the plugs the right two (when you're on the seat) were pitch black (rich) and the left two were really dry looking (lean).
I took the carbs off, looked inside the float bowls and found something weird that I'm not sure is related to my problem. The left two carbs have an orange looking plug in them [pictures below] and the right two don't.
I tried removing the plugs and running the bike but it couldn't rev past 7k on the stand like that. So I put the plugs back in. Can anyone help with my problem? Also what are those plugs and how come I only have two? Thanks guys.
Last edit: 07 Mar 2010 18:45 by vector86. Reason: Added pictures to post.
- loudhvx
09 Mar 2010 23:37 #352365
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Gpz550 can't accelerate at full throttle
There should be another jet under those covers. The covers are there to prevent the jet from getting fuel from the bowl directly. They get fuel from another passage. You should have 4 of them.
I assume you have an 82 or 83 KZ550H (Gpz)? Is that correct? I think those were the only 550 gpz years that had those plugs. Basically you just need something to seal off those openings that won't disintegrate in fuel. Also, they should not go so far into the hole that they get near the jet.
1981 KZ550 D1 gpz.
Other links.
- Thank you received: 2098
10 Mar 2010 05:04 #352386
by Patton
Replied by Patton on topic Gpz550 can't accelerate at full throttle
A small round lead fish line weight might work, pressed into the hole.
- trianglelaguna
- Thank you received: 235
10 Mar 2010 08:11 #352422
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Gpz550 can't accelerate at full throttle
sounds just like a battery with a dead cell to me...exactly like it...imo
1976 KZ900
2003 ZX12R
2007 FZ1000
10 Mar 2010 09:46 #352441
by Patton
vector86 wrote:
If not already done, would assure correct ignition timing using a strobe type timing light, and assure proper functioning of the advancer by watching it move quickly back and forth as rpm is varied by blipping the throttle.
...starts and idles fine but when I go full throttle the engine only accelerates to about 6k rpm and won't accelerate anymore unless I drop back to about 1/2 throttle....
- timebomb33
- Thank you received: 10
10 Mar 2010 10:13 #352446
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Gpz550 can't accelerate at full throttle
check the slides to see if they arf moving freely up and returning on their own and evenly it sounds to me like a diaphram problem also what kind of air filters are you using. c.v carbs can quite finicky about filters or lack of
