- Thank you received: 1
Open air area in stock airbox?
- polkat
07 Mar 2010 12:28 #351778
by polkat
Open air area in stock airbox? was created by polkat
I'm thinking about designing a custom airbox for my KZ750H3. What I'm trying to figure out is the total area of access to air in the stock box. Under the filter cap is a plastic stem with a number of small holes in the sides. Other then the crankcase breather hose, are these little holes the total access to air that the filter has? I assume that the stem goes all the way through the filter, blocking off any other access to air. Is that right? Thanks!
- rstnick
- Thank you received: 377
07 Mar 2010 16:37 #351813
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Open air area in stock airbox?
The air box cap on the 750H3 is the same part as what's used on the 650s.
On mine, the stem part goes about 1/2 way through the filter, so the bottom 1/2 of the filter is open to breath.
Some have added holes to the stem, others have cut the stem almost completely off.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- polkat
10 Mar 2010 14:49 - 10 Mar 2010 14:55 #352516
by polkat
Replied by polkat on topic Open air area in stock airbox?
After doing a lot of measuring and calculations, it appears that a custom box with an opening of 4-3/8" by 2", or if different space is needed, an opening of 3" by 2-3/4", using the same basic filtering materials, would provide the same amount of air access as the stock box. Then the opening could be made smaller or larger depending on the engine's reaction.
Anyone see a reason to disagree?
Last edit: 10 Mar 2010 14:55 by polkat.
- JMKZHI
- Thank you received: 48
11 Mar 2010 08:05 #352651
by JMKZHI
Replied by JMKZHI on topic Open air area in stock airbox?
Your bike has CV carbs. correct? ... it seems worth mentioning.
- polkat
11 Mar 2010 12:42 - 11 Mar 2010 12:44 #352711
by polkat
Yes, the usual CV34's, stock jetting (I think) and stock exhaust.
Last edit: 11 Mar 2010 12:44 by polkat.
