Accelerator Pumps
- sabell
05 Mar 2010 10:14 #351419
by sabell
'78 KZ1000A2
'79 650SR
Accelerator Pumps was created by sabell
My '79 650SR has the stock carbs on it. If I understand correctly the pump was added to these carbs in '79 to help with the hesitation the emissions crap created. I have elimated all of the emissions plumbing and capped everthing off as needed and will be spending some time with the carbs now. I gave them a good cleaning when getting the bike running last summer(the bike had sat 12 years previous) but did not replace any internals. Is it possible to by-pass the pump by capping stuff off to streamline things or am I just thinking stupid. I like the idea of getting things to work well with as few parts as possible other wise known in some circles as being a cheap ass.
'78 KZ1000A2
'79 650SR
- wompy5000
05 Mar 2010 10:26 #351422
by wompy5000
jpriderdesigns.blogspot.com
Replied by wompy5000 on topic Accelerator Pumps
The man to ask would be wired george aka carb master.
- Bluemeanie
- Thank you received: 14
07 Mar 2010 06:46 - 07 Mar 2010 06:47 #351720
by Bluemeanie
Replied by Bluemeanie on topic Accelerator Pumps
The pump was not added because of the emmision equipement but because of the lean jetting. The "standard" jetting for a 650 was 102.5 jets. When the emmisions came into play the jets were dropped down to anywhere from low to high 90 something (less power). With this lean condition you would get a hesitation upon take off. The pump gave a tiny shot of gas to overcome this condition.
I had a Kerker (not for sale ) on my bike for 28 years and just recently installed a pretty nice stock system. I rejetted my carbs but did not want lean jetting so I went with 102.5's. Now the bike does not want that extra shot of gas so I also want to eliminate that. I've been told that you can just install standard bowels and gaskets and remove system. Not sure if this is true but seems like a simple solution. Someone else needs to verify this but seems plausable.
Last edit: 07 Mar 2010 06:47 by Bluemeanie.
- sabell
07 Mar 2010 06:58 #351724
by sabell
'78 KZ1000A2
'79 650SR
Replied by sabell on topic Accelerator Pumps
Replacing bowls would probably work but would most likely mean an added expense. If that were the case then I would maybe pick up a older, cheap set of carbs from ebay that doesn't have the pump. I may just experiment a little with capping the system off and see what happens. As they say,"If you ain't cheat'n, you ain't trying."
'78 KZ1000A2
'79 650SR
- roy-b-boy-b
- Thank you received: 103
07 Mar 2010 07:00 #351725
by roy-b-boy-b
Replied by roy-b-boy-b on topic Accelerator Pumps
You could just remove the rod that goes to the pump.
I have some 26 and 28 pumpers. I just replaced the bowls with a set off of standard 26's. Roy
- sabell
07 Mar 2010 07:15 - 07 Mar 2010 12:26 #351733
by sabell
'78 KZ1000A2
'79 650SR
The small hoses that connect the bowls are dry-rotted and I just wanted to stream line things a bit, clear up the clutter.
'78 KZ1000A2
'79 650SR
Last edit: 07 Mar 2010 12:26 by sabell.
- KawiConvert
- Thank you received: 4
07 Mar 2010 09:17 #351765
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Accelerator Pumps
Yes you can ditch the pump so long as you rejet. I cut down the brass intake injectors from the pump and put bowls from a non-pumped set and they do fine.
- 6leafclover
18 Mar 2010 12:22 #354296
by 6leafclover
1979 KZ1000-E1/ST
Madison, IN
Replied by 6leafclover on topic Accelerator Pumps
Dont mean to hijack here folks but im actually trying to keep my pump but the rod is broken in two. any of you guys that are gettin rid of it like to sell me the linkage rod?
1979 KZ1000-E1/ST
Madison, IN
