Zephyr 550 carb
- rnuse
- Balls to the walls, sideways all the time
14 Feb 2010 07:46 #348205
by rnuse
1982 kz750 ltd
Drag bars, 4into1 V&H with no baffle.
1991 zephyr 550
about to give up on her.
Zephyr 550 carb was created by rnuse
Ive got this zephyr 550 for 350 bucks.
Thinking Ive done plenty of carb work on my kz, I can figure this thing out.
The air box had two pieces of foam held by silicon to work as an air filter. So I took the air box out and plan on re-jett
1982 kz750 ltd
1991 zephyr 550
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
14 Feb 2010 09:47 #348224
by Grantl
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Replied by Grantl on topic Zephyr 550 carb
I have a 1990 Zephyr 550 and recently went through the carbs. If you have any questions, let me know.
Grant.
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
- TeK9iNe
- What did you do!?!
- Thank you received: 28
14 Feb 2010 09:54 #348226
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Zephyr 550 carb
Clean it up and stick with the airbox/snorkel combo.
If you put pods on that bike, it will have terrible low/mid range hesitation. No power!
Better to use a high flow/K&N oem filter replacement, and re-jet then. Much better over all.
Unless your just going to use it on a tight twisty track! :laugh:
Probly not...
Good luck!
Probly not...
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
