4 into 1, everything else stock..jets?
- xstreamcanadian
27 Mar 2006 20:15
I am rebuilding my carbs on my sr and I know there is a lot of good info on here already so I apologize for being lazy.....
I wondered what the ideal setup is for these carbs considering the header, and also, how many turns am I needing to adjust the screws to take from the bench and onto the bike as a starting point,is it one and a half and then adjust each carb until the idle is highest? or..... again sorry for the repost.
- gas
Re: 4 into 1, everything else stock..jets?
27 Mar 2006 21:19Please Log in or Create an account to join the conversation.
- xstreamcanadian
27 Mar 2006 21:25
thanks gas I saw that one, but I am more looking for jetting advice, I saw that some guys are stock some have pods and 4into1 but I only have 4 into 1 with everything else being stock, and 15s being stock main jets i believe, should I change them or leave them stock.....
- donthekawguy
27 Mar 2006 21:47
You could try running it stock to see how it does. I think the rule of thumb is two sizes for each modification. Your main might be 115 so you could try 117. I have a set of 116 that I don't need if you want them. PM me.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- gas
27 Mar 2006 21:48
See if I can get this chart to show up.
Go to files, non model specific, page 4, jetting guidlines KZ650. The chart is there.
This is a test to see if I can establish an internal link files
Post edited by: gas, at: 2006/03/28 01:06
- xstreamcanadian
28 Mar 2006 06:15
yup it worked and now I will be late for work!!! but it was worth it thanks
- xstreamcanadian
28 Mar 2006 20:48
ok so to summ it up, I should be running 105 mains with stock pilots. Or with all things being equal, run 110s and 17s and throw on some individual pod filters
