Zephyr 550 carb issue
  • rnuse
  • rnuse's Avatar Topic Author
  • Balls to the walls, sideways all the time
14 Feb 2010 07:17
#348198
Ive got this zephyr 550 (w/ a title!) off craigslist for 350 bucks.
Thinking Ive done plenty of carb work on my kz, I can figure this thing out.
The air box had two pieces of foam held by silicon to work as an air filter. So I took the air box out and plan on re-jetting the bike for some pods. But until then I have nothing on the carbs.(Dangerous I know)
I got it running but wont rev anywhere over 6k.
Jets problem?
If so I may have a second bike ready to rock for summer after some bigger jets.
Any opinions?
1982 kz750 ltd
Drag bars, 4into1 V&H with no baffle.
1991 zephyr 550
about to give up on her.
  • testarossa
  • testarossa's Avatar
Re: Zephyr 550 carb issue
14 Feb 2010 07:27
#348200
Are you reasonably sure that these are the stock carbs? If so, then I doubt that you need bigger jets to get it rev past 6K. I would start by rebuilding the carbs. Go ahead and jet for the pods while your in there, but it should run with the stock jets. Others who have more experience with this motor can give you jet size suggestions. It would be worth it to get a FSM and check out the ignition as well.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
17 Feb 2010 16:45
#348858
Jets problem?
Any opinions?
Jet problem? :laugh: You think!
You absolutely must have some form of permanent filtration for the carburetors. Something oem/aftermarket designed for those carbs/bike.
Otherwise you will destroy the rings/cylinders.
If you change filters you need to change jets, so find something your going to just leave on there.
It won't rev because its way too lean without filtration.
Get the air filtration, then you can start fiddling with jets to find the ones that net you the most power.
Good luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • pyxen
  • pyxen's Avatar
09 Mar 2010 08:00 - 09 Mar 2010 08:05
#352173
What mains did you use with the pods? I'm having the same problem with my Zeph. I installed 115s across all 4, but I think I'm just going to go back to stock, and use the pods when I rebuild my KZ550 (still not done).
My main problem is she bogs (almost a whoof/whoosh sound through the intake) down at 1/4 throttle, and stalls. if I can manage to get it up past the 3k mark at 1/4 throttle, it'll pull up fine on the stand (in neutral).
Oh, and (with the pods off) noticed that the slides kind of fluttered in the 1/4 range.. didn't open up smoothly. Almost like it just couldn't do it. Not enough vacuum to lift properly?
Haven't tried riding the bike yet though..because it's just not consistent enough.
I'm assuming you have CVK30s?
84 KZ550-F2 LTD
93 ZR550-B4
Last edit: 09 Mar 2010 08:05 by pyxen.
  • rnuse
13 Jul 2010 16:05
#382359
Yea I do. As far as I know I have stock Jets in it. I have not messed with this bike in a very long time until tonight. I Think my diaphragms on top of the carbs may be to blame. Because my 1 and 3 carb slides are very smooth,while the others move freely but there is a weird "hesitation" when I push them up by hand. might take them apart tonight if I'm feeling froggy enough.
1982 kz750 ltd
1991 zephyr 550
  • mjg15
  • mjg15's Avatar
13 Jul 2010 16:13
#382361
You either need pods and a jet kit OR whatever it takes to restore your stock airbox/filter to usuability. My ZR runs very nicely w/stock jetting and airbox in place.
Here's a link to ZR550 site:
www.allthings550.com/forum/
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
