Blow-through carbs for a turbo setup
  • Ituen
  • Ituen's Avatar Topic Author
  • Rider
13 Feb 2010 03:57 - 13 Feb 2010 03:59
#347991
Which carbs are best for a blow-through turbo setup? Can the 34mm Keihin CV carbs be modified for turbo use?
1982 KZ750 E
Kawasaki Rider
Last edit: 13 Feb 2010 03:59 by Ituen.
  • otakar
  • otakar's Avatar
Re: Blow-through carbs for a turbo setup
13 Feb 2010 06:26
#348006
I may be wrong. but I believe that you can't use any CV carbs for blow threw aspiration. CV carbs rely on ambient pressure differential to operate the slide diaphragms. You would have to use a manual slide carburetor which you can pressurize the float bole on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • PLUMMEN
  • PLUMMEN's Avatar
13 Feb 2010 07:40 - 13 Feb 2010 07:42
#348025
Last edit: 13 Feb 2010 07:42 by PLUMMEN.
  • PLUMMEN
  • PLUMMEN's Avatar
13 Feb 2010 07:42 - 13 Feb 2010 07:44
#348026
i couldnt find the rider to get details ,but i saw those beast last summer in monterrey with what apears to be some sort of cv carbs
Last edit: 13 Feb 2010 07:44 by PLUMMEN.
  • TexasKZ
  • TexasKZ's Avatar
13 Feb 2010 08:37
#348033
You might want to look arond on zrxoa.com. There are several turbo guys over there who could answer your questions. You can also talk to the folks at Mr. Turbo (Terry Kizer's shop). They still make a kit for the kz1000.
  • timebomb33
  • timebomb33's Avatar
13 Feb 2010 08:39 - 13 Feb 2010 08:40
#348034
xj 650 seca turbo used c.v carbs factory installed and they are a blow thru set-up
I THINK MY POWERBAND BROKE
Last edit: 13 Feb 2010 08:40 by timebomb33.
