- Thank you received: 1
Petrol in Air Box Filter
- kz1100warrior
08 Feb 2010 01:08 #347193
by kz1100warrior
Petrol in Air Box Filter was created by kz1100warrior
Hi to All.
Please somebody help, I have a KZ1100 Shaft 1981 A1 model.
Stock carbs stock exhausts.
As the title states, I have noticed petrol in my airbox filter casing. What could the cause be.
Valve sitting to tight, shims to tight.
I have recently changed the cam chain but this problem was there before, I also changed the rings last year doen valve etc.
Anybody
Anybody
- Kawickrice
- Thank you received: 18
08 Feb 2010 06:08 #347208
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Petrol in Air Box Filter
Have you checked your float height and needles and seats in the carbs?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kz1100warrior
08 Feb 2010 06:26 #347211
by kz1100warrior
Replied by kz1100warrior on topic Petrol in Air Box Filter
Hi, floats all the same height. needles correct redone carbs on Sat, but was still getting petrol in.
Thanks
Thanks
- Old Man Rock
- Thank you received: 225
08 Feb 2010 07:11 #347214
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Petrol in Air Box Filter
Question.... Unknown to me anyways but here goes...
Some or all (again unknown to me) of the stock OEM airbox configurations have the engine breather tubes feeding back into the airbox for collecting back presure oils from spewing all over...
With that in mind, are you seeing oil as well as gas in your airbox?
If so, check your oil site glass for possible gas in the engine case...
Just a thought...
OMR
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- YUKABODOS
08 Feb 2010 08:01 #347216
by YUKABODOS
Replied by YUKABODOS on topic Petrol in Air Box Filter
Float height, Petcock operating properly...vacume or gravity...did you turn off the petcock?
Fuel in the airfilter usually means the floats are stuck and allowing an oveabundence of fuel into the bowls which overflows backwards out of the carbs into the airbox.
Changing the oil is not a bad idea, once the problem is resolved, given the realivly low cost of doing so.
- bill_wilcox100
- Thank you received: 5
08 Feb 2010 08:16 - 08 Feb 2010 08:21 #347218
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Petrol in Air Box Filter
Do you have a new, large, high quality and inline Fuel Filter to stop all that stuff from your old Fuel Tank from reaching the Needle Valve and free flowing. If not, then raw Fuel can back into Air Box. Don't ask how I know. :blush:
Best of success,
Bill
PS
Don't forget to add your year, model and location in your signature to get the best responses... and yes it's considered real friendly too.
Bill
Best of success,
Bill
PS
Bill
Upgrades:
Montreal, Canada
Last edit: 08 Feb 2010 08:21 by bill_wilcox100.
- Thank you received: 2098
08 Feb 2010 09:08 #347233
by Patton
Replied by Patton on topic Petrol in Air Box Filter
kz1100warrior wrote:
See this recent thread.
Click here> kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=346929
Good Luck!
...KZ1100 Shaft 1981 A1 model.
Stock carbs...noticed petrol in my airbox filter casing. What could the cause be....
Good Luck!
