carb comparison 82 kz750 spectre vs 83 kz750 ltd
- warogue
02 Feb 2010 01:24 #345993
by warogue
1982 KZ750-N Spectre (Stock)
1987 EN450 454LTD
Sebastian, FL
carb comparison 82 kz750 spectre vs 83 kz750 ltd was created by warogue
I have a 82 kz750 spectre and am wanting to but a new set of carbs to rebuild. I have found a set off a 83 kz750 ltd that look identicle but do have different part numbers. The 82 is 16001-1526 and the 83 is 16001-1739. Does anyone know if these are compatible?
Thanks,
Drew
Thanks,
Drew
1987 EN450 454LTD
Sebastian, FL
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
02 Feb 2010 07:29 #346026
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic carb comparison 82 kz750 spectre vs 83 kz750 ltd
If I'm not mistaken the LTD used Kehin carbs where the Spectre used Mikunis. I'm not 100% on that though, I'm going from memory. Even if they were the same carb they would carry a different part number since the Spectre carbs were painted black. In Kawasaki partsland that is enough reason to give a new part number to something that is otherwise identical. If given a choice I would stick with the Mikinis since parts are much easier to find.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- warogue
02 Feb 2010 12:21 #346077
by warogue
1987 EN450 454LTD
Sebastian, FL
Replied by warogue on topic carb comparison 82 kz750 spectre vs 83 kz750 ltd
Thanks for the reply. My 82 has Kehin and the seller with the other carbs said those were kehin cvk34's, which I am sure mine are also. I soon as I have a chance to verify my carbs I'll respond for sure.
Thanks again,
Thanks again,
1987 EN450 454LTD
Sebastian, FL
